Help Needed
Old Jun 18, 2016 | 08:17 PM
Per4mance's Avatar
Per4mance
It will get here. They love us.
Old Jun 18, 2016 | 09:35 PM
Yahiko's Avatar
Yahiko
I'll be stopping by the PostOffice Monday.
BTW I may of found a nice trailer 36' gooseneck.
Will have to see if it fits into the budget.
28' lower deck. Needs some skin repair. But that is easy.
I think it time to stop the
Slowe I see you said oil in the degas bottle is that correct?
You may want to do a Dawn dish soap cleaning first.
You will want to look that one up and verify the steps first.
Oil in the coolant is not good. It usually comes from a ruptured
oil cooler. When you pull the oil filter do you see what looks like
a chocolate milkshake?
If that is the case then you need to do the oil cooler first before
the flushing or you will have a really bad mess. If you can get your
hands on a usable used oil cooler that you can install for the flush
and the week or so after then remove it and stick the new cooler in.
The reason for leaving a cooler in after the flush is to catch all the grit
that the chemical flush will knock loose and plug the oil cooler up
very fast. But the people that are really stuck are the ones that have a
ruptured oil cooler and no spare one to toss in for the short time to
filter all the grit out.
One of the FTE members came up with something to back flush the
oil cooler to help clear the grit out of the cooler before it turned into
hard rock like substance. I don't recall who it was.
Sean <BR>
6.0L Tech Folder
Old Jun 22, 2016 | 09:40 PM
Slowe's Avatar
Slowe
Hello to everyone I will update everyone this coming Tuesday and look forward to getting my truck fixed and to make sure that it is fixed properly I plan on getting the sct live wire so I can keep an eye on the eot and ect spreads after done also looking for some info its pushing oil into the degas bottle but I have not noticed any water in the oil so do you think its just a ruptured oil cooler also it has not spewed out of the degas bottle not even alittle bit so my question is do you think there may be a chance the head gaskets are still good and not blown ? I will post this coming Tuesday to let everyone know what they say at the shop and go from there oh by the way it has 174,000 mile and is an 06 king ranch crew cab with 20x14 fuel wheels and 35s I wil post pictures after its fixed and running good ! also do you guys have any good advive on a set-up that makes decent power maybe 400-425 and still somewhat dependable I would appreciate any advice abouts turbos regulated fuel returns and or injectors and which type of FASS system I would like to improve what I have and make decent power but stay safe in doing so thanks for any advice on set-ups that are proven winners
jimbo1969
Jul 26, 2016 10:03 AM
Yahiko
Mar 29, 2016 09:23 PM
Yahiko
Feb 8, 2016 05:08 PM
fordtrucksforever
Jan 25, 2016 07:40 PM
geeride
Sep 21, 2015 08:17 AM
