Wire connections under the dash
Old Jun 13, 2016 | 04:37 PM
azgunner's Avatar
azgunner
I have tried to get a picture on this but got nothing that was useful, so I am gonna try this again a slightly different way.
Under the dash by the steering column I have 2 sets of grey connections, 1 is for the turn signal switch, the other one is the one that I have no idea on and need help with. It was ripped apart accidentally on the female side. I either need a pic or the color order on the plug. The truck is a 1984 ford f250 351W non tilt and non cruise control. As it sits right now because of this plug I have no turn signals/hazzards nor break lights in the rear. can anyone please tell me the female side of this connector so I can just bypass the connector and use but connectors to reconnect these wires. The connector is a curved grey , with 7 ports on top and 4 on the bottom.
Old Jun 13, 2016 | 04:52 PM
Franklin2's Avatar
Franklin2
Not always but most of the time each connector has the same color wire going through the connection. So if you find a lightgreen wire on the one connector, it usually hooks to the lightgreen on the other connector.
Is this not the case for this connector pair?
Old Jun 13, 2016 | 05:14 PM
azgunner's Avatar
azgunner
There are some wires that dont match up.....this is why I am getting frustrated with it.
Old Jun 13, 2016 | 06:26 PM
Blackduck59's Avatar
Blackduck59
If you have 2 sets of those curved grey connectors it sounds like it was set up for speed control. It just inserts between the plug half on the steering column and the half in the main harness. Pictures would really help
Component Testing - ???Gary's Garagemahal
Again this is for an 86 but should give you most of what you need. Page 148 under component testing. Pins marked 511 and 296 are to do with speed control and my truck colours on 511 do not match
Would have to go through my shed notes to ID the rest of the pins. The numbers alongside the colour codes are circuit numbers and show up the various diagrams, such as turn and hazard drawings.
Old Jun 14, 2016 | 07:57 AM
azgunner's Avatar
azgunner
Blackduck59, So after looking up some things after what you had said about the speed control, It does look like my truck is supposed to have it. But the last people to have owned the truck well lets just say that they did some things that were not reasonable and just dismantled things that didn't need to be. And so with that said, I saw a box under the dash and had no idea what it was for, but after your post I looked into it and BAM! that box is the control for the speed sensor. I am partly color blind so I am gonna have my wife look at the wires and see if they actually match up in color. If so I will just connect them back up and hopefully fix this issue. Then I guess I need to figure out how to get the cruise control back and working again. Thank you for that tidbit of info that got me going in the right path.
Old Jun 14, 2016 | 07:35 PM
Blackduck59
Pin 511 is also the brake light feed to the switch.
Cheers Steve
Old Jun 15, 2016 | 09:38 AM
azgunner's Avatar
azgunner
ok so here is now my dilemma, colors on the connector that is intact.
blk/pur strp
lt grn
lt blu
orng/blue
ltgrn/orng
wht/red stripe
yel/ blu stripe
grn/wht X2
wht/blu
dk blu
wht/pnk or red X2
now the wires that are loose
yel/blu hash
yel/blu dots
grn/orng
grn
wht/blu
wht/blk(maybe blur but faded???)
grn/wht
wht/red stripe
blk/pur
dk blu
orn/blu
most match up but some dont...any ideas here?
Old Jun 15, 2016 | 03:06 PM
azgunner's Avatar
azgunner
OK so for anyone that is following this issue, I was out messing with the truck today, and found that 90% of the wires to the connector that I messed up were comming from the turn signal switch wire connection. Only 2 or 3 wires are left over that were not in that harness. Maybe someone can give some insite now on how this all reconnects together and I get can get my break lights and turn signals to work again.
azgunner
Jun 13, 2016 08:55 AM
SolarKing
Oct 18, 2013 07:25 PM
sprint
Nov 17, 2007 04:12 PM
stang_crazy_gt
Oct 25, 2007 12:14 PM
SuperFord
13
Nov 19, 2005 07:56 AM
