wire harness pin locations
Old Nov 17, 2007 | 09:54 AM
sprint's Avatar
sprint
can anyone tell me the pin locations on the steering column wire harness for a 68 f100 w/3spd man. the ******* mechanic (me) didn't make a very good diagram when i took it apart. now its all messed up. any help would be greatly appreciated. thanks
Old Nov 17, 2007 | 02:02 PM
blue68f100's Avatar
blue68f100
Are you referring on how the connector is wired?
Should match up to the mating connector under the dash.
Old Nov 17, 2007 | 02:10 PM
sprint's Avatar
sprint
the wire colors on each side of the connetor are differant.
thanks
Old Nov 17, 2007 | 03:01 PM
sprint's Avatar
sprint
yes the six pin connector with 5 wires going up the steering column, need to now which wires go where in the connetor. the only diagram I can find is for a 69 which there is a couple differant color wires that they didn't use in 68.
thanks
Old Nov 17, 2007 | 04:12 PM
blue68f100's Avatar
blue68f100
My 69 is AT, but the wiring should be the same. Mine si out of the truck with the column torn apart. Here is what I have looking at the face with the bar closer to the top
Blu/yel Blue
Char/wht grn
wht/bl
