Coolant leak 97 F150
Need a little help out of the box thinking
Only when running heat or defrost, coolant leak looks like it's coming out of the bell housing. I have a supercharger so very difficult to see behind motor, but with inspection camera, heater hose lines look dry. firewall looks dry. No coolant in cab. No steam on windows or smell. Pretty sure not casting/ freeze plugs because absolutely no leaking with heat off. Can run for days with no loss, then turn on heat and within minutes/ seconds coolant puddling in driveway. Is the hose that runs through valley pressurized only when heat is on? I saw a few older threads but as far as I could tell none specified heat on/ heat off conditions. Just started problem after doing some other work, hoses were off radiator and intercooler, replaced radiator. None of those connections are the culprit.
Thanks--
98 F150 Lariat 1900 TVS S/C Chiller Killer I/C 19PSI Snow performance WMI
Thanks--
BernMidwest
04-13-2011 04:14 PM
