coolant in the valley
Hello, thanks to anyone up front for the help. I have a 97 or 98 model f150 that developed a coolant leak. The valley of the motor is full of antifreeze. Coolant is leaking down the rear of the engine on the passenger side. I have searched and looked at the posts about the heater core hose. Is this the most likely cause? Or intake manifold leak?
thanks, james
thanks, james
there are two lines in the valley that could have a leak.. there is also an aluminum crossover tube at the front of the intake manifold from one side to the other, over the alternator. The gasket on the crossover to the bottom of the manifold on the passenger side is an area of concern. See if you can see any wetness by #1 plug or injector.-- thats what i had.... i will post a couple photos of the valley and the manifold- crossover gasket (o-ring) that was leaking... look at the VEE and you can see the two tubes that could also be a problem... my valley was full also.
Jesseprince717
1999 to 2016 Super Duty
02-14-2020 12:26 PM
shark1979
27
07-18-2010 03:48 PM
