Three Fuel Tanks?
Old Jun 12, 2016 | 10:06 AM
chukar's Avatar
chukar
Three Fuel Tanks?
The '74 4x4 P/U I bought a few months back is missing the middle of its three fuel tanks, and the selection valve on the floor inside the truck. I'd like to have all three tanks available. I've searched but not found anything that explains how the system works or, more importantly, how to go about getting it working the way it was designed to work.
I'd really appreciate any advice!
Vic
Old Jun 12, 2016 | 01:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford did not install 3 fuel tanks. There's either an in-cab (except Super & Crew Cabs) and aft axle tank. The in-cab tank was cancelled after 1977.
Or a mid-ship and aft axle tank, one of which was an option. The factory valve installed on the floor (1973/74) is only designed to work with 2.
But aftermarket companies also installed auxiliary fuel tanks, the caps are usually behind doors that were riveted to the bed sides.
Factory installed: 1973/76's have exposed fuel caps, 1977/79's have fuel doors.
Old Jun 12, 2016 | 07:30 PM
chukar's Avatar
chukar
So was my '74 made with two fuel doors, both of which look like factory made? I'm more confused than before. :-)
My truck has the in-cab and aft axle tanks, but there is a fuel door for a middle tank that looks totally factory made; no riveting.
Old Jun 12, 2016 | 09:02 PM
hasteranger's Avatar
hasteranger
Fuel doors mean someone has installed a later bed and perhaps the midship and aft tanks of the donor truck as well, but it didn't come that way.
Old Jun 12, 2016 | 09:07 PM
chukar's Avatar
chukar
OK, that stops my head scratchin'.
Now, has anyone ever plumbed and wired up a system to get three tanks working? With a 429 in this truck I'm thinking a third tank may come in handy, especially for the long trips we take in the west for hunting, that would be my reason, camping (see reason #1), and fishing.
Old Jun 13, 2016 | 09:52 AM
NumberDummy
No factory fuel doors until 1977, 1973/76 Stylesides have exposed fuel caps.
Note applications in parts catalog pic below for 1977/ (1977/79) F100/350 Styleside (body style 99) 27840-1 left quarter panels (bedsides).
Old Jun 13, 2016 | 02:41 PM
hasteranger
Yes, the aftermarket saddle tanks were hooked up that way, but I've never messed with them.
I've seen pictures of floor valves and I think they were manual valves.
Old Jun 13, 2016 | 11:10 PM
Blue and White's Avatar
Blue and White
Personally I would be happy to "loose" the in cab tank. I am not crazy about driving around with gas behind the seat. The rear tank and side tank would give decent range and also work with adapted factory type valves for 2 tanks.
Not sure on frame width on your '74... if it has the wider frame it could take the 38 gallon rear tank. Good range by itself and really good with a mid-ship tank added.
Old Jun 14, 2016 | 07:36 AM
hasteranger
74 4x4 f250 *should* have narrow frame. No idea what rear tank is back there.
Old Jun 14, 2016 | 11:28 AM
NumberDummy
33 1/2" width between the inner frame rails behind the cab:
1961/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79: F350 Regular Cabs on the 140" wheelbase & F350 Cab & Chassis.
Old Jun 14, 2016 | 02:05 PM
greentruck72's Avatar
greentruck72
this may not help... but my 72 when i got it had 3 tanks on/in it ( 1 in-cab and 1 in front of each rear wheel), the way they had them set up was they all ran to manual selector switch, no sending units on either of the back two( guess they just ran the back two empty than switched to the other). like i said it may not help but that's how it was on my 72.
Old Jul 28, 2016 | 05:23 PM
chukar's Avatar
chukar
Thanks, everyone, for the information. And I agree with blue and white about have a gas tank in-cab so I'll have to make up my mind about it sometime soon.
Old Jul 28, 2016 | 09:00 PM
lasermike's Avatar
lasermike
My '74 F250 Super Cab has three tanks.
The for and aft factory tanks with exposed caps and a third tank outboard of the frame rails on the passenger side. It's filled through a locking door screwed onto the side of the box.
The factory manual selector valve was replaced with a three input valve, it's currently frozen and the saddle tank has 5+ year old gas in it. I'm stuck using the aux or forward tank but then again, I only drive 5000 miles a decade so it's not so bad.
Any tricks for fueling the thing without spilling on my shoes? I hate when that happens.
tbruz
13
Oct 4, 2015 08:51 PM
Country_boy_2007
Nov 29, 2012 06:07 AM
360F100
20
Jan 20, 2011 07:44 AM
customhighboy74
Jul 23, 2010 08:46 PM
Jrcarp
Dec 31, 2005 10:19 AM
