Door handle/ latch adjustment?
Old Jun 11, 2016 | 04:49 PM
64highboy's Avatar
64highboy
Just installed my outer handles and the latch mechanism. Ive had the doors apart a couple of times now and for some reason on final assembly the outer door handle doesnt want to push the lever on the latch enough to disengage the little gear on the latch. Has anyone else had this problem and is there any adjustment?
Old Jun 11, 2016 | 08:58 PM
gangstakr's Avatar
gangstakr
You can adjust, just like you've done. Use white lithium grease on the mechanism inside door. Once lubricated the results are overwhelming.
Be surprised what a little cleaning and lubing does!!!
Old Jun 11, 2016 | 11:03 PM
64highboy's Avatar
64highboy
I did soak it down with wd40 before i put them in. I didnt adjust them though, i was asking if there was anyway to adjust the throw in the handle or latch.
Old Jun 11, 2016 | 11:49 PM
64highboy's Avatar
64highboy
I just pulled the handle out inspected everything, put a little twist in the leverpart of the latch hosed it with wd and what do you know works perfect. Thanks
Old Jun 14, 2016 | 09:01 AM
TWONY's Avatar
TWONY
Glad to hear, I actually had an issue with a remake inner door handle spline once I replaced it the outer button wouldn't move at all. A slight bend to the inner rod and it started working fine. Quite a PIA though.
hillcountryflt
Nov 30, 2014 12:33 PM
lilrobo
Aug 25, 2013 11:53 AM
ghall
Jul 18, 2007 10:14 PM
Heavenword1
Aerostar
Jan 31, 2007 11:36 AM
40hotrod
1947 and Older Ford Trucks
Aug 3, 2005 01:46 PM
