1997 e4od install issues
#33
Just a quick question - have you check for codes (engine/CEL codes) to see if Trans is throwing errors? I had similar problems with mine recently and the codes helped w/proper diagnosis. (Was bad solenoid, Trans in limp mode) --that was my issue, check for codes to see what's happening w/your connection etc.
#34
56: Transmission Oil Temperature sensor too high – Transmissions
91: Transmission SS 1 circuit/solenoid problem
92: Transmission SS 2 circuit/solenoid problem
93: Transmission TCC circuit/solenoid problem
94: Transmission TCC circuit/solenoid problem
99: Transmission EPC circuit/solenoid failure
Something is very wrong with either the wiring in your truck, or the solenoid pack you got. Your computer is saying it has no connection at all to any of the solenoids in the transmission. Another thing I just realized, is what are you doing for your speedometer? The 1997 E4OD will not have a spot on the tailshaft for the speed sensor your 1990 requires.
#36
Well, like I said, the transmission will not shift correctly at all without the speed sensor hooked up, and the '97 E4OD should not even have a spot for your speed sensor.
You also need to figure out why you have no connection at all to your solenoid pack. How is the wiring on the solenoid pack connector?
#37
maddmudder13
09-20-2007 09:00 AM
payner22
05-30-2005 05:34 PM
ty77
10-31-2003 12:19 PM
Holder20
10-25-2003 09:48 PM
