Sponsored by: Real Truck
Replacement Fuel Tanks
Old Jun 10, 2016 | 01:29 PM
Layson's Avatar
Layson
Originally Posted by Firekite
That's absolutely silly. People will believe anything.
I don't think it is a question of believing. Your truck is heavier on the driver side. Your transfer case, DEF fluid, and your fuel tank are on that side of the truck. Plus these new trucks have alot softer springs then what used to be in these trucks. So it rides nice for you.
There are lots of threads about it and it is very rare to see someone complain about passenger side lean, just driver side.
Old Jun 10, 2016 | 03:21 PM
ugh3012's Avatar
ugh3012
Originally Posted by slownsy
With the Titan 50 gallons how many gallons are useable. From peaple who has them.
Frank.
I don't know the answer to that. But, with aux tank it is 100% usable.
Old Jun 15, 2016 | 12:25 PM
chukker's Avatar
chukker
Frank.
All the gallons are useable, same as in the original - just don't run your fuel tank dry as you will cease to proceed down the road! Running out of fuel is still running out of fuel.
I had Titan install my fuel tank up at their company headquarters in Idaho Falls. James Patience is the guy you see on the YouTube videos and he installed mine. I was so impressed with their operation and service. Since I did mine on a 2002 F350 after owning it for over ten years, I kick myself for not having done this sooner. chukker
Old Jun 16, 2016 | 08:08 PM
New F150 Guy's Avatar
New F150 Guy
Originally Posted by Badger Mike
I have 2013 6.7 crew cab short box, and am done with the small fuel tank. Has anyone had luck finding a dealership that will install a titan 50 gallon tank and not void the warranty?
I had a friend install mine since I didn't have time. Any local shop can likely do it, as it's not a difficult install. Do you already have a mech you trust? If so they will prolly know who to refer you to if they won't do it themselves.
Old Jun 16, 2016 | 08:11 PM
New F150 Guy
Originally Posted by Layson
I bet that truck has quite the driver side lean with that large replacement titan tank in it.
I personally really like the in-bed tanks better.
I haven't noticed much if any additional drivers side lean. What I have noticed is that with a full tank the weight must sit more aft and it changes rake.
Of course I don't notice either now since I can inflate the drivers side airbag slightly more than the other if I want to take out the sag and lean.
Old Jun 16, 2016 | 08:13 PM
New F150 Guy
Frank.
The most I've put back in has been 46.7 as I haven't wanted to push it any closer so far.
Old Jun 17, 2016 | 01:15 PM
ssunit1's Avatar
ssunit1
Just got a 50gal tank in bed Aux tank from Lund. If fits below my bed cover and is gravity feed. Haven't taken any trips with it yet but looking forward to the added range.
Old Dec 22, 2017 | 06:46 PM
cjssr's Avatar
cjssr
I've added 45 gallons one time to the 50 gallon one but never usually run it that low. Range now shows 900+ miles till empty on fill up. I added a in-bed 55 gallon with transfer pump this fall as Ive been running multiple 2200 mile trips so now with 105 gallons I can shop for fuel at best price not buy because I have to at any price. Also makes some lonely stretches of highway better not searching for fuel
Old Dec 22, 2017 | 06:48 PM
Just Strokin's Avatar
Just Strokin
Frank.
I have a 65 gallon in my CCLB and have used 60 of the 65 gallons between a fuel stop last year.
Old Dec 23, 2017 | 01:29 PM
ligito's Avatar
ligito
Just have to make more pee stops.
ezrider6298
Apr 5, 2021 10:33 AM
Fishwater2002
6.7L Power Stroke Diesel
13
Apr 1, 2021 07:59 PM
Diesel 724
Feb 4, 2015 09:15 PM
Captainkoop
Oct 24, 2014 01:14 PM
