Auxiliary fuel tank
Auxiliary fuel tank
I put a 90 gallon "L" shaped tank in the back of my truck under my tool box. It is only vented at the filler caps (I put one on both ends). I installed a pump to transfer fuel from that tank to my factory front tank. I run off the rear tank, then swap to the front. When the front is low I just pump some fuel in from the aux tank till it's full. I do that till the aux tank is empty then I fill completely up again and do it all over. I also run Stanadyne in each tank.
Diesel 724
02-04-2015 09:15 PM
