Fuel Filter Change
Old Jun 8, 2016 | 09:20 PM
LetSC's Avatar
LetSC
Fuel Filter Change
Changed got fuel the other day within 2 hours it started missing and acting up now the smoke is pouring out the exhaust like you have never seen. Added some additive and still smoking. Changed both fuel filters and now won't even crank over need help 2006 Ford F350 king ranch!!!!!!!!!!!!!!!!!
Old Jun 9, 2016 | 01:57 AM
Yahiko's Avatar
Yahiko
Welcome to FTE
Lets get to work.
First charge the batteries.
Next turn key on and listen for pump sounds on the frame under the driver.
Now some questions.
Did you put a new O-ring on both caps and apply some clean engine oil?
The lower cap can be a bear. Are you sure that it is seated? If not you can
pull air into the system and make all sorts of misses and smoke.
You might want to start with taking the lower cap off and checking the
O-ring and filter to make sure all is well. Screw it back in and torque it to
18 Ft/Lb. BTW you should see 2 O-rings one for the cap and one on the filter
end. Oil both and the one on the cap is the only one that you can replace.
Also up inside the filter you may see a black seal oil on that won't hurt.
Snap the filter back into the cap and start the threads to engage and be sure
that you don't cross-thread. Torque cap to 18 Ft/Lb.
Sean <BR>
6.0L Tech Folder
Old Jun 9, 2016 | 10:32 AM
diesel_dan's Avatar
diesel_dan
another possibility is you got dirt in there when you did the upper filter, which went to the injectors -- did you keep things nice and clean doing both? What color is the smoke out of the tail pipe?
Old Jun 9, 2016 | 02:17 PM
TooManyToys.'s Avatar
TooManyToys.
Sounds like an injector failure with a hydro locked motor if the batteries aren't depleted. See the Excursion thread.
https://www.ford-trucks.com/forums/1...excursion.html
grassman2852
Dec 17, 2016 06:23 PM
norman2012
Nov 24, 2016 04:17 PM
F33lmywrath
Sep 14, 2016 10:33 AM
MauleOne
Sep 18, 2010 12:24 AM
new2diesel2
Dec 20, 2005 05:21 PM
