HPOP testing
Old Jun 8, 2016 | 02:36 PM
vivitron21's Avatar
vivitron21
HPOP testing
Hi, I've posted a thread before about my problem with my 2003 6.0 diesel Excursion but it was about a year ago.
At present I've come to the conclusion that my HPOP is bad, I pressure tested my system and could not hear any leaks until I removed my oil cooler and the oil in the reservoir was bubbling.
I purchased a new HPOP from ForDiesel and installed it but I'm still getting air coming through my oil cooler reservoir so I sent the HPOP back assuming it was faulty, they sent me a replacement which is doing exactly the same. if I put 110lbs of shop air through the top of the HPOP some of the air is exiting the bottom of the HPOP so can anyone please confirm that its not supposed to do this and I have been sent another bad pump.
Thanks for any help
Old Jun 8, 2016 | 06:42 PM
BLADE35's Avatar
BLADE35
sounds Bad
What brand pump
Old Jun 8, 2016 | 09:57 PM
vivitron21's Avatar
vivitron21
I didn't know there was a "brand" its the round one, says bostech fuel injection on the box lol
I'm getting worried now that even if they send me one that's ok that it wont last long with all the work that has to be done to replace the damn thing lol
Old Jun 8, 2016 | 10:11 PM
BLADE35's Avatar
BLADE35
We'll those early round pumps people have been rebuilding but not doing a thuro job be it lazy or not able to get parts to change the pistons on that pump
OEM is even hit and miss from the feedback on here
When you pull the pump can you spin the gear make sure it's not binding
Lots of folks 3rd pump is a charm deal and it's BS there a lot of work to get at
Adrenaline pumps are new and haven't heard any issue yet probably the best way to go IMO
I would have went for an adrenaline couple year back when mine went if it wasn't a week before. Xmas when it died
Old Jun 8, 2016 | 10:22 PM
vivitron21's Avatar
vivitron21
yes I've seen the adrenaline pump, twice the price almost but its sounding like it would be the better investment, especially since its costing me $35 to keep returning defective pumps
Old Jun 8, 2016 | 10:44 PM
163junk's Avatar
163junk
Did you command the IPR closed?
Old Jun 8, 2016 | 11:00 PM
vivitron21's Avatar
vivitron21
I'm using the special tool you buy that you attach in place of the IPR valve, I also put shop air into the top of the hpop while sat on the bench and it was leaking air out of the bottom.
my original pump had a lot more air coming from it than my 2 (what I believe to be faulty) replacements did but I'm assuming at 110psi shop air it shouldn't be leaking anything through it since it works with pressures around 3000psi
Old Jun 9, 2016 | 01:35 AM
Yahiko's Avatar
Yahiko
You would in most cases find a check valve. But with this your not
going to have any pressure when the engine stops so there will not
be any back pressure. It might have a anti drain back valve. Did you
turn the engine over to fill the pump with oil? That might make a difference
with a reman pump. Worth a try to see if it seals.
Worth a try to see if that makes it not blow air bubbles.
Sean <BR>
6.0L Tech Folder
Old Jun 9, 2016 | 12:08 PM
vivitron21's Avatar
vivitron21
the top of my engine is completely stripped down, turbo removed, oil cooler removed, inlet manifold removed, EGR and wiring loom all removed
Old Jul 5, 2016 | 09:17 PM
BigGreenEx's Avatar
BigGreenEx
Did you get this resolved?
Old Jul 6, 2016 | 12:06 PM
vivitron21's Avatar
vivitron21
unfortunately not, I'm still trying to return the faulty pump they sent me and get my core back so I can order an adrenaline HPOP
Old Jul 6, 2016 | 02:39 PM
Yahiko's Avatar
Yahiko
Did you use a VISA card or one of the other major brands to pay for it?
If they give you problems just get the card provider to help you.
Sean <BR>
6.0L Tech Folder
Rob_A
Sep 3, 2018 10:37 PM
Per4mance
Jun 28, 2018 10:02 AM
dothedew192
Feb 21, 2016 09:58 AM
Baatzy
Aug 5, 2015 10:32 PM
dkhollins
Aug 30, 2010 01:29 PM
