Transmission problem
Old Jun 6, 2016 | 11:35 AM
lowrider50's Avatar
lowrider50
Recently bought a 95 f-250 with the E40D transmission. I had no problems with it but the fluid looked a little dirty and had a slight burnt smell so I decided to drop the pan and change the filter and drain the torque converter. I replaced 7 quarts from the pan and let the truck run for about 30 sec. then added 6 more quarts. I started it up and ran for about a minute. and shut it off. Then restarted because I wanted to shift it thru the gears to circulate the fluid. Now I have no movement in any gear and the truck shut off. Not sure what to do next. Any help appricated.
Old Jun 6, 2016 | 11:48 AM
4DB's Avatar
4DB
Please correct me if I'm not remembering this correctly, but an E4OD takes a lot more than 13 quarts, doesn't it? I think I put 18 in mine.
Old Jun 6, 2016 | 12:01 PM
rla2005's Avatar
rla2005
X2.....16-18 quarts in my experience.
Old Jun 6, 2016 | 12:43 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You got 18 quarts out of the trans just from dropping the pan? That sounds like how much it would take after a rebuild. How much fluid is on the dipstick? To me, it sounds way overfilled.
Old Jun 6, 2016 | 12:45 PM
lowrider50's Avatar
lowrider50
I measured what I took out. A little over 7 qts. from the pan and 6 from the torque converter.
Old Jun 6, 2016 | 12:46 PM
Jagesage's Avatar
Jagesage
The capacity of the E4OD according to the Haynes Manual is 16.5-17.6 qts or right in that range.
Old Jun 6, 2016 | 03:32 PM
lowrider50's Avatar
lowrider50
I put the same amount in that I took out. For some reason I don't think it think the fluid is circulating, the dipstick is showing way overfilled.
Old Jun 6, 2016 | 03:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The filter may not be in place. Or you just may not have idled it long enough to fill the torque converter. It should take 2-3 minutes to fill the converter. If the converter is very low you won't have engagement in any gear.
Old Jun 6, 2016 | 08:26 PM
lowrider50's Avatar
lowrider50
Will try it again tomorrow Mark, Let you know how I make out.
Old Jun 7, 2016 | 11:17 AM
lowrider50's Avatar
lowrider50
You were right Mark, The converter just needed more time to fill up. Thanks for your help.
Old Jun 7, 2016 | 12:38 PM
Mark Kovalsky
I'm glad it was that easy!
Rlchv70
Sep 7, 2014 10:44 AM
halaferd
Oct 13, 2011 06:36 PM
vze2sgxa
May 29, 2009 02:15 PM
copracer288
Nov 10, 2008 10:05 AM
JBronco
1978 - 1996 Big Bronco
Feb 8, 2005 08:25 PM
