How much trans fluid when changing?
Old Nov 10, 2008 | 04:42 AM
copracer288's Avatar
copracer288
I'm going to be doing the fluid and filter in my '93 F250 w/ E4OD.
I know the owner's manual says 15.7 qts but I'm wondering how much actually comes out draining the pan and torque converter.
I plan on using Mobil 1 ATF and certainly don't want to buy more of that than I have to.
Thanks.
Rob
'93 F250 supercab 4X4 460"
'78 F150 camper special 4X4 460"
Old Nov 10, 2008 | 05:30 AM
TexasGuy001's Avatar
TexasGuy001
I bet your going to need about 10-12 quarts. My old truck had an E40D and it had a larger pan. I know that my 4R70W needs about 4.5-5 quarts when just dropping the pan. I service mine about every year, so thats all I do is drop the pan and change the filter and replenish the lost fluid. When I first got my truck several years ago I did that along with draining the torque convertor and I think I needed about 8-10 quarts. I can't remember exactly. Maybe someone else can be more helpful. I will say this do not overfill it.
Old Nov 10, 2008 | 09:48 AM
Conanski's Avatar
Conanski
If you drain both the tranny and TC you'll need 13-14 quarts for sure.
Old Nov 10, 2008 | 10:05 AM
quicklook2's Avatar
quicklook2
close to 14-15 qts. for me.
get a big pan when draining the t.c. not an oil change little pan.
i use the ford filter and make sure it is on properly.
GeeeMCeee
Oct 26, 2014 08:32 AM
M-715
Mar 29, 2010 09:02 PM
Raymond Bourque
Mar 21, 2006 10:25 PM
MCalvin460CI
Jul 13, 2003 11:59 AM
1 Big Mike
Jan 19, 2003 11:57 AM
