transmission question
Old Jun 28, 2016 | 01:53 PM
hdman6's Avatar
hdman6
post trans install
So new trans is installed, along with a new 6.0 cooler. I reused my BTS valve body they i got with my DP tuner. Just sent back the old trans for the core charge return. So when i dropped the old trans pan a few of the valve body bolt that hold it up were approx 1/2 turned out, like working loose out. I am now wondering if that had something to do with the original slipping that occured. Either way i'm sure i was overdue for a new trans. So Ford gives 3 yr unlimited miles warrenty as long s i bought the new cooler. Now i do notice the shifting is a lot tighter and smoother, but at certain rpm's i det like a loud growl type noise at approx 62 mph.. go to 65 and it dissappears it happens at a couple of other mphs but im not sure the speed. Trans temps seems to be real good. I have Bg in it for trns fluid. I have tried all my DP settings and it seems to be working fine. I did replace the flywheel at the time since it was missing a few teeth. Other that that small noise i am fully satisfied... Jeff
Old Jun 28, 2016 | 03:45 PM
HKusp's Avatar
HKusp
Glad to hear all is well. I have my HD4R100 for almost a month now and really love it.
Old May 23, 2017 | 12:22 AM
kennyburns's Avatar
kennyburns
4R100 transmission filter replacement/service
Hello everyone. I am concerned about the transmission filter in my 02 Excursion. I drained out 7 quarts and pulled off the old filter. I noticed that the filter is really not held in place very securely. It is just shoved up a hole in the bottom of the tranni with a orange hard o-ring. You can wobble it pretty easy with your fingers. Is this anything I should worry about? Is there a aftermarket support bracket available? I know if it falls out and lands in the bottom of the pan, I will have big problems. I would appreciate any suggestions.
Thanks - KWB
Old May 23, 2017 | 09:14 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you have the right filter the pan will hold it in place. Once the pan is on it's impossible for the filter to fall out. I've never seen an aftermarket bracket anywhere. I suppose you could make one, but I don't think it is necessary.
Old May 23, 2017 | 09:30 AM
kennyburns's Avatar
kennyburns
Thank you for the information Mark.
69ford99
1997 - 2003 F150
Dec 17, 2015 11:27 PM
emgee
Sep 16, 2015 05:19 PM
Fordclevor
1983 - 2012 Ranger & B-Series
Apr 20, 2015 10:26 PM
ryan f150 4x4
May 16, 2007 11:58 PM
Ford204x4
Dec 30, 2002 12:42 PM
