PO756 Trans code
Old Apr 20, 2015 | 01:13 PM
Fordclevor's Avatar
Fordclevor
PO756 Trans code
I have a 96 ranger 4.0 auto 4x4 that was pulling a PO756 code. So I went the route of changing the valve body,solinoids, filter and 7qrts of fluid . put it all back together and I am still having the same problem. flashing O/D at about 60mph and it won't shift from 2-3 unless I let off the gas When I dropped the pan there was nothing in it except a little sludge Any and all help would greatly be appreciated
Old Apr 20, 2015 | 01:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Does it still report the same P0756 code?
Old Apr 20, 2015 | 04:35 PM
Fordclevor's Avatar
Fordclevor
Yea its the only code that shows and still doing the same thing
Old Apr 20, 2015 | 08:09 PM
Mark Kovalsky
The only way that code can set is if the electrical circuit is good AND the solenoid doesn't move when it should. Only a bad solenoid can set this code.
Old Apr 20, 2015 | 10:26 PM
Fordclevor's Avatar
Fordclevor
Thanks I will try and switch out the solenoid and see what happens
JoseFeli
Mar 4, 2011 09:52 PM
