Door panel reinforcement idea
Old Jun 2, 2016 | 01:35 PM
mudder460's Avatar
mudder460
I just picked up a 74 crew cab and was thinking about the door panels. I know the back door panels are hard to find. I was thinking about taking mine and reinforcing the back of them with fiberglass. Anyone try this yet? I just want to give it some extra strength.
Old Jun 2, 2016 | 03:33 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As long as the mount pins are good and secure you should not have a need to reinforce. But here is and idea or 2. I overhauled these so much because they have the stainless trim piece.
Make sure your door pull straps are good and secure.
1. One reinforce the area that the mount pins go in. JB weld or your fiberglass idea?
2. Grind off just a bit of the door panel (behind the area that is covered when the arm rest and finger cup are installed), its the area that the 2 bolts hold the panel off a bit.
3. Metal tab reinforce the plastic piece that is usually attached to the metal bracket under the finger cup when installed.
4. Use the longer than the Ford ones, GM push pins.The GM ones also have more flat disk surface area.
5. Use some 2" wide velcro as a back up attachment to the long run L&R area above the finger cup and at the bottom of the panel.
It might be ugly on the back side, but they are NOT going anywhere once mounted. CC panels are hard to find for sure.
Old Jun 2, 2016 | 03:38 PM
77&79F250's Avatar
77&79F250
Well duh...I just looked at the the pics of the CC panel and most of my tips only help with front door panels....
Good door pull straps, longer push pins, reinforced push pin mount area and velcro are all I have then.
Old Jun 2, 2016 | 05:26 PM
mudder460's Avatar
mudder460
Great tips! I'm going to use the JB weld and longer push pins for sure!
Matt1966
16
Mar 1, 2022 08:56 PM
Killgore
May 29, 2013 06:43 PM
YoungMT Hick
Appearance & Dress-Up
Aug 14, 2007 08:59 PM
fatfenders
32
Mar 19, 2004 06:34 PM
oft
Apr 24, 2002 04:51 PM
