Rough Start, Runs Fine
Old Jun 2, 2016 | 10:54 AM
Raleigh234's Avatar
Raleigh234
I've finally crossed out the fuel system as the culprit for the issue at large. After resealing the fuel bowl, my 97 F350 OBS STILL starts rough. It takes a longer time to turn over, and when it does, it sounds like it's misfiring really bad at first, then brings itself to a normal purr. Starter is a year old, and checked out good, fuel system is clean all the way to the heads. What else am I looking for?
Old Jun 2, 2016 | 11:08 AM
444dieselrod's Avatar
444dieselrod
Bad glow plugs. Ohm them out to find the bad ones. Measure voltage from the GP side of the regulator to ensure its good also.
Old Jun 2, 2016 | 10:16 PM
76f250highboys's Avatar
76f250highboys
Is there a voltage regulator for the glow plugs? I cant get more than a week or two before I am down a glow plug or two on my 95
Old Jun 2, 2016 | 10:25 PM
fordpride's Avatar
fordpride
If you're burning out gp's in a couple weeks then I'd say your GPR is staying on
Old Jun 2, 2016 | 10:57 PM
Raleigh234's Avatar
Raleigh234
Found them. 2 and 6 were burned out. Replaced all 8 with a set of motorcrafts, and she's running like new now. I can finally move on to more "fun" projects, like installing this coolant filter...
Old Jun 3, 2016 | 12:52 AM
farmert's Avatar
farmert
Or he has Autolites in it.
Old Jun 3, 2016 | 10:30 PM
76f250highboys
The dash GP light goes out and the alt gauge goes up at the same time so I am pretty sure that GP are not staying on. Have used both Ford and aftermarket glow plugs with the same result.
Old Jun 5, 2016 | 11:51 AM
knottyrope's Avatar
knottyrope
jump the GPR for 30 seconds and then start it, if it starts easier then you may have PCM issue
if using block heater and start nice then there is a issue with controlling GPR
Old Jun 5, 2016 | 02:34 PM
fordpride's Avatar
fordpride
Crank it then let the gp's turn off and check the GPR with a meter to see if voltage is still passing through
Old Jun 5, 2016 | 02:35 PM
fordpride's Avatar
fordpride
Both of these are signs of a bad GPR. Not a pcm issue
Old Jun 6, 2016 | 02:15 PM
76f250highboys
Plugging in the block heater for a few hours is how I start it now. After a few hours it starts right up and is good for the day. Truck is not a daily driver but still it would be nice to fix this problem.
Thanks for the help, I will check the GPR
Old Jun 6, 2016 | 02:31 PM
z31freakify's Avatar
z31freakify
Glow plug relay, there's an upgrade made by Stancor? That supposly is better, maybe someone with part # chimes in.
Old Jun 6, 2016 | 03:20 PM
76f250highboys
Thanks for that. I googled and found the Stancor relay. 586-902 part # I believe. Should be better as it is a much larger relay. Ordering that upgrade today.
kent hittle
16
Feb 11, 2016 04:18 PM
Mike Hannahs
29
Oct 9, 2013 08:16 PM
Opossum
Oct 17, 2012 12:18 PM
TRIKSTR
Mar 27, 2008 04:24 PM
tazmania18235
20
May 4, 2004 06:44 PM
