I have been working on on 7.3 pre turbo 1989? New glow plugs good batteries bought the manual glow plug switch which is powering glow plugs good fuel getting to injectors new fuel filter still will not start on its own it seems to load up on fuel but won't start squirt starting fluid starts up but seems flooded eventually cleans it self out and runs great getting 12 volts plus to glow plugs checked injector fuel to them I just don't know what to try any more I hate to give up because it runs so good if I plug it in seems to help to but its not that cold should not need to?????
If it starts on ether and not glow plugs, something isnt right with the glow plugs, or its just plain not turning over fast enough. Are you sure the starter is spinning it over good?
It's got new batteries it turns over real fast I believe I'm going to plug it in tonight and see what happens in the morning awhile back it started when ithad been plugged in so we will see I picked up a compression checker that if it doesn't start being plugged in I guess I will do a compression check and make sure I'm not wasting my time it just sounds so impressive when it s running I hate to give up
When it's cold, make sure the cold advance solenoid is activated(pull the wire with the key on, engine off and see if it clicks). If not, you have a problem.
It'll often /start/ without it, but will smoke horribly due to how retarded it is.
what brand glow plugs did you put in it? if they were autolites, they are most likely burned out already. i have seen autolites burn out after one start.
champions, bosch, wellmans, dieselRX, AC delco, or any other glow plug that is not made by motorcraft/beru usually just dont work properly in these engines.
there are some people that swear by off brands, but 99% of us have had nothing but bad luck with the off brands.
I have autolites pulled 2 both are shot .Now that I have the glow plug relay that's manual I am getting 12 volt plus what is an affordable glow plug to get because I have a feeling all are gonna be shot . I hate to give up when it runs so good when I do get it started.
As Tom said, Autolites are utter crap, Beru/Motorcraft are 'considered' the best.
I have had good luck with the DieselRX/Wellman glow plugs, and will continue to use them, even though some of us believe they are crap. I've not had bulging issues, and they generally stay working just fine.
Remember, though, with a manual glow plug setup you can kill /ANY/ glow plug by holding the power too long. I've done that a couple of times over the years, usually when something /else/ is wrong and I'm "blaming" my glow plugs for not getting hot enough, so I held the button down longer.
Do note that if you intend to keep a manual glow plug system, you may want to pick up some 6.9-style(spade top) glow plugs(DRX00088) to use with your 7.3 relay and wiring. For a manual system, it warms up a little slower, gives you more 'leeway' with leaving the button pushed down too long. It's still fast, though - 10 second range.
Motorcraft/beru plugs like Tom said. Rockauto has them if you dont mind waiting on shipping. You could ask the store you got the autolites from if they can get motorcraft. Maybe they will credit you for the Autolites.
Thanks everyone I went and got some motor craft held the manual relay for about 15 seconds praise the lord started like it should now time to put the 1935 cab and front clip on it and getter done
Gonna use the frame and running gear out of this 1989 f350 dually 4x4 and put a 1935 Chevy 1.5 ton cab and front clip rat rod diesel to pull my camper to the lake as we
