Is there some secret . . . . ???
Old May 31, 2016 | 06:15 PM
24 Carat's Avatar
24 Carat
To getting the #$&%$ multi-pin plug off of the EEC / ECM / PCM / etc, etc, etc ????
I am thinking 21 years has it just adhered with grime ?
Old May 31, 2016 | 06:29 PM
xTHANATOPSISx's Avatar
xTHANATOPSISx
I'd say you're right.
But just in case, you loosened the bolt in the middle, right?
Old May 31, 2016 | 06:34 PM
Lead Head's Avatar
Lead Head
If I remember correctly, loosening the bolt on the PCM connector should physically pull the connector away from the PCM without requiring any tugging/pulling?
Old May 31, 2016 | 06:50 PM
Conanski's Avatar
Conanski
Well actually there is a trick to it, you break the bolt lose and if you keep turning it will get somewhat tight again, and if you keep turning some more and look closely you will see the harness connector slowly backing out of the PCM connector until finally it stops moving and the bolt is lose again. Now it's fully disconnected and the harness can be disconnected.
Old May 31, 2016 | 07:10 PM
24 Carat's Avatar
24 Carat
Yup I did. From what I am reading here a reinstall of the bolt and close scrutiny should help.
Old Jun 1, 2016 | 05:02 PM
Lead Head's Avatar
Lead Head
Hmm? Removing the bolt all the way should pull the PCM connector with it.
Old Jun 1, 2016 | 06:09 PM
dixie460's Avatar
dixie460
Yeah, after you loosen the bolt as far as it will go (til it just freewheels) then the connector should practically fall off the PCM.
If not then just get a screwdriver and gently work around the edges. It can't be stuck THAT bad, I wouldn't think.
Mike321
May 2, 2017 06:49 AM
riverking
Aug 4, 2014 10:33 PM
Gcrop
33
Mar 14, 2009 09:29 AM
sidwaz
Jan 27, 2009 09:11 PM
TwelveAlpha
Dec 10, 2006 08:29 PM
