pcm connector bolt
Old Aug 4, 2014 | 09:39 AM
riverking's Avatar
riverking
pcm connector bolt
my WTstart lite was flickering! causing hard starts and dying on 01 f350 7.3 i attempted to tighten connection bolt from wire harness to pcm with a 1/4 rathet an 10mm socket. the bolt broke into. my question, where do i get another bolt lke this one?
Old Aug 4, 2014 | 10:08 AM
whitetmw's Avatar
whitetmw
I don't think you can get just the OEM Bolt. However, A Hardware Store may have what you need.
Old Aug 4, 2014 | 01:04 PM
David7.3's Avatar
David7.3
Thats tough Bro, it comes with the harness, im sure theres not to many of them lying around, did you get the bolt out from the PCM? If I had to guess on what size bolt you need I would say 8X1.25x25mm, double check of course, the problem is the narrow head that fits into the harness connector, do you have any friends at ford? Maybe they can hook you up.
Old Aug 4, 2014 | 02:45 PM
Pikachu's Avatar
Pikachu
If you can find the right length and thread in an Allen socket bolt, that would probably work well too.
Old Aug 4, 2014 | 07:14 PM
riverking's Avatar
riverking
I need about 6'' of all thread, but i can't find it in metric!
Old Aug 4, 2014 | 07:37 PM
Pikachu's Avatar
Pikachu
Fastenal carries it in metric. They may or may not stock it in the retail stores, but they can order it in.
Old Aug 4, 2014 | 10:10 PM
Will104's Avatar
Will104
Maybe try a local junk yard i know i could find a few around here, the only pita would be getting the bolt retainer out of the plug
Old Aug 4, 2014 | 10:33 PM
riverking's Avatar
riverking
thanks, i forgot about fastenal. yeah getting it out without damage would b great
Mike321
May 2, 2017 06:49 AM
24 Carat
Jun 1, 2016 06:09 PM
Yougotthehit
Mar 10, 2010 09:50 PM
sidwaz
Jan 27, 2009 09:11 PM
SReiman
1983 - 2012 Ranger & B-Series
Jan 24, 2004 08:24 PM
