Can a floormat be repaired?
Old May 26, 2016 | 07:00 AM
Highboy4x4's Avatar
Highboy4x4
I just picked up a nos floormat for my 1964 pickup and over the years it appears that a mouse decided it was hungry enough to eat away at some of the rubber. Is it possible to repair this? The damage is located just in front of the seat mount on the passenger side. Any help is greatly appreciated.
Old May 26, 2016 | 10:23 AM
My1964ford's Avatar
My1964ford
I honestly don't know how to fix it but you could put that black gorilla tape over it on the top and bottom as a temporary fix so it doesn't get torn or something (that's if you're already using it)
Old May 26, 2016 | 06:24 PM
john jamieson's Avatar
john jamieson
I would look for some similar type material. Car mat or tool box liner? Make the damaged hole a regular shape and lay over the repair material. Then cut the new material using the hole as a template. Use some carpet tape ton the underside to hold everything together. Then use some seam sealer to seal and glue the edges.
civicmindeddogooder
Jan 5, 2011 06:46 AM
damac
15
Feb 10, 2010 03:44 PM
Greywolf
All Things Towing
Jul 16, 2008 08:38 PM
wickymustang
Garage & Workshop
Feb 15, 2006 10:33 AM
packrat56
Jul 30, 2004 10:12 AM
