Firewall hole sealer putty?
Old Jul 30, 2004 | 02:53 AM
packrat56's Avatar
packrat56
Whats that sticky moldable black stuff called that we used to use to seal the holes around wires, etc. going thorugh the firewall? Where is it available?
Old Jul 30, 2004 | 03:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can get butyl tape, I think that is what the stuff I am thinking of is called, from winshield glass shops. They also have some newer materials that can seal up a hole permanently...
Always protect the wires with a gromet or something. That sticky stuff can let the wires move enuf to short out. Some grommets and bushings are available at electrical supply houses or the home box stores.
Old Jul 30, 2004 | 03:33 AM
packrat56's Avatar
packrat56
I do use gromets, I agree they are needed. However, I find at times that, especially with odd groups going through one hole, that there is not a good seal. Is that butyl tape stuff black?
Old Jul 30, 2004 | 03:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
It is black and VERY sticky. I just wanted to make sure you weren't using the mastic alone. A sealer is needed on those wire bundles. Some people have used roofing tar but the solvents attack the wire covering.
Old Jul 30, 2004 | 04:15 AM
packrat56's Avatar
packrat56
Cool, Ill check out the glass shop! Thanks much.
Old Jul 30, 2004 | 04:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
You buy it in long rope like lengths (10'?) but if you only needed a small amount you might be able to talk them out of some for the right price
Throw some talc on it after you have it molded in to make the outside less sticky.
I don't use that corrugated split plastic tube for bundling wires anymore. I hate the stuff. I use the black plastic spiral split tubing available at Radio Shack and Wall Mart etc in 10' lengths. RS # 278-1638 but it is cheaper at WM at $1.98/10' last time I checked.
Old Jul 30, 2004 | 05:43 AM
53Merc's Avatar
53Merc
Question 2ndary followup Question
Torque1st:
Good idea about the talc!
I just bought some of that "clear" spiral stuff at Princess Auto up in the great white north... looked cool but didn't see it in black, why did you stop using the corrugated plastic stuff?
GW
Old Jul 30, 2004 | 06:03 AM
Torque1st's Avatar
Torque1st
Posting Legend
Frankly that stuff is a pain to get around the wires, never looks very good, and it can open up a finger too. Once you start using that spiral cut tubing you will never go back to that spit tube. You can wrap the spiral tubing around any size wire bundle any way you want. From just enough to hold the wires together to armor plating.
I have looked for the black split tube in 50 or 100' rolls but I have been unable to find it in anything but clear at the industrial supply houses. Clear is used widely in industry but I like the looks of the black for automotive work. I bought it for years at Radio Shack until I spotted it at Wally World. I know that when I dig into my truck mods I will need a couple hundred feet. Even at $2 per 10' it doesn't cost much. My son uses it all the time on computers he builds that have to look good. The kinds with windows and lights inside to show off that $500 graphics card that the gamers use. You can also use it to protect hoses and tubing from abrasion. The hydraulic supply houses have some real tough stuff for hoses but it is too stiff for wire work.
Old Jul 30, 2004 | 06:35 AM
4tl8ford's Avatar
4tl8ford
Eastwood Co. sells OEM type Firewall "Putty'
Old Jul 30, 2004 | 10:12 AM
Homespun91's Avatar
Homespun91
Try a local heating/air conditioning dealer/repairman- they use the same stuff on furnaces where the A/C lines go into the ductwork for the A-coil.
packrat56's Avatar
packrat56
This is the stuff! Eastwood:
3M Flexible Strip Caulk 20 yd
"This black, non-hardening, paintable caulk is just the solution for sealing irregular areas in firewalls, rocker panels, trunks, around tail lights, or just about anywhere gaps need to be plugged. Effectively seals out water, dust, and dirt. Duplicates the caulking material used by many auto manufacturers."
Mgjfam
Dec 22, 2016 03:23 PM
oldbleu
WTB - Parts & other
Oct 4, 2016 04:25 PM
1949f1
29
Jul 28, 2016 04:19 AM
vidaliaman
May 6, 2016 11:28 PM
66 ford lover
Aug 18, 2012 10:18 PM
