Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Thick foam?
Old Feb 2, 2006 | 02:00 PM
wickymustang's Avatar
wickymustang
Thick foam?
Has anyone ever had any success in using those thick foam mats that you cut to fit the outline of tools to organize them in your took box? I saw them at Sears and if I could get the outlines to be nice and neat and tight fitting to the tool I would love to use them. Any advice on what would make this possible? I have a dremel, exacto knives, razor blades, ect.
Old Feb 2, 2006 | 02:04 PM
amish77's Avatar
amish77
use two layers of foam. Place the first down as a backer, then cut the otehr one to shape and glue the two together. The exacto knives or razor blades would probly work best for this. Just lay out your tools how you want them then either trace around them with a marker or something or simply cut around them. Sounds like a great idea for organization, I wish I thought of it.
Old Feb 2, 2006 | 02:31 PM
pitrow's Avatar
pitrow
I use them in mine. They can be pretty nice if you do it right. They come with a piece of paper that you trace the outline of the tools onto and then cut out both the paper and the foam. Spend some time and do it right and they're nice and tight fitting and work very well. I just used a razor blade, though I think and exacto type knife would probably be better for the curves. It comes with a knife that works ok too.
Old Feb 2, 2006 | 05:53 PM
Ultraute's Avatar
Ultraute
The foam will cut best if compressed real thin. Take a piece of plywood and clamp it tight over the foam. Draw the desired shape on the plywood, Then take your dremel or a jig saw and cut out both the wood and the foam below it.
Old Feb 2, 2006 | 06:14 PM
cfordaz's Avatar
cfordaz
If it is very thick go to a thrift store and find one of those electric kitchen knives for a buck or two. I worked in an upholstery shop and we had a foam cutter but they had previously used the electric knife.
Calvin
Old Feb 2, 2006 | 07:09 PM
wickymustang
I was figuring on using 1 layer, with the drawer liner already in the box as the under one and not gluing them together until I am sure of the drawer order that will work best for me.
Old Feb 2, 2006 | 07:55 PM
amish77's Avatar
amish77
yeah come to think of it that sounds like a good idea. don't want it too thick.
Old Feb 2, 2006 | 08:25 PM
wickymustang
And this way, I can always pull it out and rearrange what drawer holds what. So a sharp exacto knife and a lot of time will result in tight fitting cuts that are smooth? I saw a kid who tried this and it looked like he chewed out the shapes with his teeth.
Old Feb 2, 2006 | 09:46 PM
Bdox's Avatar
Bdox
cfordaz called it with the electric carving knife. Works great for larger cuts.
I made a pistol case using foam, but the shapes were too small for the carving knife idea so I just made 1/4" thick plywood templates on my scroll saw. Press the template down hard to compress the foam and trace the outline with an X-acto knife. Bingo, perfect.
Old Feb 2, 2006 | 10:59 PM
racoonbandit's Avatar
racoonbandit
I have them in my tool box at work. We used 1/4" red on the bottom then 1/2 black on top. So it is easy to see if there is a tool missing at the end of the job. Looks nice and helps to keep a good inventory of your tools.
Matt
Old Feb 3, 2006 | 09:22 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
Instead of buying the foam in the tool section, go look around in the camping section and look for a foam bed roll pad. You can usually find the same foam for much less and select colors if you want. I think I bought one roll for $5 or so (for sure les than $10), and I did my entire box (6 on top, 3 middle, 1 bottom) and still have some left over. I bought my foam at Bass Pro Shops and not Sears, though. There are different types of foam in that section, though, so make sure you look closely.
Oh, yeah, I cut it with and X-acto with no problem.
Old Feb 3, 2006 | 11:24 PM
wickymustang
I got to thinking and some of the tools came with cheap plastic cases, mainly to hold them in the shrinkwrap with the label, but they are hollow on the backside. Would it be possible to turn these over, and fill them with Great Stuff gap filler and then cut it flush. Would that hold up or no?
Old Feb 15, 2006 | 10:33 AM
midlf's Avatar
midlf
Try the great stuff idea. If it works you are in. If it doesn't you are no worse off than you are now.
