Need help!!!!
Old May 24, 2016 | 10:12 PM
Adam Vargas's Avatar
Adam Vargas
Need help!!!!
Ok i have a 1977 f100 302 5.0 i have just done a complete tune up just about new everything! Just put in a new carburetor today and it sounds great! The PROBLEM is when its nice and warmed up and i start driving it starts to miss and then cuts of completely but if I put it in the neutral Or Park it'll start up again and sound great it only cuts out in Drive (i also got a new coil and fuel pump and filter still didnt fix the problem) can someone please help
Old May 25, 2016 | 08:28 AM
baddad457's Avatar
baddad457
Did you adjust the carb when you bolted it on, or did you just bolt it on an hope for the best ? What is the new carb ? (brand as in Holley, Motorcraft, etc)
Old May 26, 2016 | 04:55 AM
Adam Vargas
Yes the new carb is adjusted perfectly and the timing is done
Old May 26, 2016 | 12:46 PM
baddad457's Avatar
baddad457
What did you set the timing at ? Is the vacuum advance working ?
Old May 26, 2016 | 02:45 PM
Tedster9's Avatar
Tedster9
Is the distributor connected to manifold vacuum source or a ported vacuum source?
rahnpreston
31
Oct 14, 2013 01:04 PM
Robby8279
Nov 16, 2011 06:20 PM
Diesel_Brad
Nov 17, 2010 11:10 PM
70T351W
May 17, 2005 10:42 PM
