Weird readings while battery is charging
Old May 28, 2016 | 08:11 PM
Montync's Avatar
Montync
Question Weird readings while battery is charging
I have an issue. when putting a multimeter on my battery while running the reading is unreadable. Off I can get a clear reading. It has a new alternator new battery and new voltage regulator, new ground cable, new terminals. The voltage reading in the dash has 13.3.to 13.4. The alternator test at 3 diffrerent parts stores passed. 14.8, 15 max. what could be the issue? video linked showing what it is doinghttps://www.facebook.com/michael.o.montague/videos/vb.754081208/10154298946976209/?type=2&theater&notif_t=video_processed&notif_id=1464484112487606
Old May 29, 2016 | 12:30 AM
Beanscoot's Avatar
Beanscoot
The digital meter is trying to respond to the constant tiny fluctuations in voltage from the running alternator.
If you used an analog meter you shouldn't have this problem.
Old May 29, 2016 | 12:46 AM
Tedster9's Avatar
Tedster9
Analog meters are useful, but a modern digital multimeter has NO problems reading these kinds of voltages. Make sure the battery inside the multimeter itself is fresh.
They give VERY wonky results when starting to get weak, that will cause some headscratching. Ask me how I know.
NotEnoughTrucks2014
Apr 4, 2017 06:48 PM
Dads76XLT
50
Oct 13, 2016 05:01 PM
The_mayor
Feb 19, 2015 01:08 PM
dbickford
21
Nov 22, 2013 01:49 PM
DRanchero
Electrical Systems/Wiring
Mar 15, 2007 12:01 AM
