05 No Start issues
Old May 25, 2016 | 01:55 PM
WatsonR's Avatar
WatsonR
And you gave it both cam/crank new sensors? It needs both those to be a 1 for sync before FICM can be a 1 sync.
So if you've done both sensors and pinch wiggle the harness to see if you could find the spot.... I see no reason to not get a harness. I also don't recommend a used one, it may very well have its own issues or worse.
Old May 25, 2016 | 01:58 PM
WatsonR's Avatar
WatsonR
If it doesn't see the fan or the plugs bad that could keep it from running.... not keep it from sync.
Once it sees those two sensors it should give FICM sync.
Old May 25, 2016 | 02:01 PM
WatsonR's Avatar
WatsonR
There is a thread posted about ICP bucking. The poster added a schematic for PCM, that drawing should tell you where the wires attach, what pins..... and possibly a place to start checking the wires for continuity of the can/crank sensors.
Old May 25, 2016 | 02:09 PM
Savspanky's Avatar
Savspanky
Yes I have the pin out charts and wire diagrams for ecu and ficm . Along with wire diagrams. I have done ohm checks on both can and crank sensors all within spec. I was not getting any codes till I got the glow plug one and the p2665 code. This is driving me nuts , I have harness all unwrapped up to ficm . Only thing I can think is a bad socket on a connector.
Old May 25, 2016 | 02:10 PM
Savspanky's Avatar
Savspanky
Sorry p2552 code
Old May 25, 2016 | 02:12 PM
Savspanky's Avatar
Savspanky
Sorry p2552 code
Be nice if some one could ohm out pin 28 on middle ecu connector and let me know what a good reading is I'm getting 5000 ohms and the trouble shooting guide has 10000 ohms
Old May 25, 2016 | 02:23 PM
WatsonR's Avatar
WatsonR
If the wires very near the connector appear to have small white marks, like the wire sheath was stretched, it's probably bad.
Best I can do to help.
Old May 25, 2016 | 02:30 PM
Savspanky's Avatar
Savspanky
Best I a can do to help.
Thanks I have replaced cam sensor wiring all the way to ecm , I'll go after crank Sensor next . Ohms good but might not carry current
Old May 25, 2016 | 02:46 PM
WatsonR's Avatar
WatsonR
I think your on the right track. It has to be one of them.
Old May 25, 2016 | 10:39 PM
BLADE35's Avatar
BLADE35
CRANKSHAFT SENSOR REMOVAL PDF
https://www.ford-trucks.com/forums/a...6&d=1350773254
CMP/CKP WIRE DIAGRAM PDF
https://www.ford-trucks.com/forums/a...7&d=1350773292
CRANKSHAFT SENSOR TROUBLESHOOT PDF
https://www.ford-trucks.com/forums/a...5&d=1350773220
CAMSHAFT SENSOR TROUBLESHOOT PDF
https://www.ford-trucks.com/forums/a...4&d=1350773182
PCM PLUG PINOUT
http://api.viglink.com/api/click?for...13382481502533
Old Jun 13, 2016 | 06:33 AM
Savspanky's Avatar
Savspanky
Ok new ficm didn't help any of this , might try a crank sensor , but really it will spin over but won't even try to fire injectors. Someone said fan connection would that keep it from running. Also read about tone ring on crank moving but how to check that with out pulling front cover?? Anyone near Savannah with a better scanner that can see cam/crank sync bs ficm sync??
Burgess090906
Nov 5, 2017 09:01 PM
sureshot-!
Jun 13, 2016 12:43 PM
kornfanjoe
Mar 13, 2013 06:09 PM
HTP
Mar 19, 2012 10:07 AM
npccpartsman
Oct 7, 2009 12:18 PM
