Intermittent Stall / Skip While Driving
I run with and edge insight for monitoring and have the clone IDS at home.
Ed's FICM w/ atlas 40. No tune on PCM. FICM sync is good even when it skips. All other parameters look fine. New fuel filters, oil change, and cam position sensor within 400 miles. Injectors are new ford remans w/ less than 5K on them. No bubbles. New injector harness as well. All high pressure oil components are new. Starts quick every time and purrs at idle.
I do not have a fuel pressure gauge. It has the blue spring mod, but I have no way to verify the pressure. I have wiggled all over the main harness.
Suggestions please.
Suggestions please.
Doubt it is your crank position sensor, they rarely go bad.
