Cam Position Sensor Codes
Old Sep 28, 2009 | 08:07 AM
npccpartsman's Avatar
npccpartsman
I've had a P2614 intermittently for a couple of years but never had any kind of a no start condition until recently. Never found anything as far as wire chaffing after spending a whole day of harness testing/reinforcing. Didn't replace the sensor since the truck started later on in the day. Now it's thrown a P0341, which is similar but not exactly the same diagnosis. Anyone had these and what was the remedy?
Old Oct 7, 2009 | 12:18 PM
npccpartsman
Update: I replaced my cam position sensor this morning to eliminate that little fly in the ointment. I noticed that I had a good accumulation of oil on the plug and harness and upon inspection of the old CMP sensor the sealing o-ring at the block had a large chunk gone. I suppose it's been this way from the factory because it's never been out of the block. Cleaned the plug and harness with electrical cleaner, inspected it, and called it good. At least I'll know to start in the harness if I have this problem again.
rowekmr
Feb 15, 2017 09:26 PM
Jonathan Day
2004 - 2008 F150
Oct 3, 2016 04:06 PM
Headviking
Jan 21, 2016 09:25 AM
AJB201
Oct 26, 2012 10:14 PM
tidexp
23
Sep 9, 2012 08:37 PM
