Please help
Old 05-19-2016, 12:32 PM
barberman91's Avatar
barberman91
barberman91 is offline
Trailering
Please help
I have recently purchased a 1991 e250 camper van. On my first trip, I stopped to fill the gas tanks. When I filled the front one, the gas pumped never clicked off and gas was pouring from underneath the van. Any ideas what would cause this?
Old 05-19-2016, 01:07 PM
vettex2's Avatar
vettex2
vettex2 is offline
You have to crawl under and look
Old 05-19-2016, 03:17 PM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
The gas pump nozzle detects a "full condition" by use of a venturi tube in the dispensing pipe. Gasoline backup blocks the venturi and trips the handle linkage if it's working correctly. I don't see the problem being on your end unless you've smelled raw gasoline or caused a puddle while driving.
Old 05-19-2016, 04:19 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
I once had a gas pump do this with my E150 and freaked out--thought it was a blown fuel hose between my filler neck and tank--but it never happened again. I can only attribute it to a bad gas nozzle. It was at Costco, where the pumps are maintained very well.
Did you have the nozzle in with the bend facing downward? If you put it in upside down or sideways the sensor may not work properly.
Let's assume it's OK...
George
Old 05-19-2016, 04:44 PM
barberman91
Trailering
I tried it right side up and upside down. No change. It did it at every gas pump that I stopped at, from michigan to South Carolina.
Old 05-20-2016, 05:25 AM
JWA's Avatar
JWA
JWA is online now
Received 1,408 Likes on 1,111 Posts
Am I understanding this correctly---gasoline leaks from under the van during filling, not splashing back out through the filler neck opening in the body side?
If that's the case then Vettex2 offers the best advice---has to be a problem with the filler neck tubing leading into the fuel tank.
This is something I'd want to look into ASAP---could be a very dangerous situation.
PLEASE let us know what you eventually find with this---could possibly be of huge help to another at some point.
Old 05-20-2016, 08:04 AM
jimandnena's Avatar
jimandnena
jimandnena is offline
Did the previous owner have the tanks worked on? It the pump/sender unit wasn't securely fastened, that would leave a 3 inch hole open at the top of the tank. If the fill pipe was leaking, it should have started dumping fuel as soon as the gas nozzle was turned on. There is also a fuel vapor vent hose in a grommet on top the tank, about 1 inch diameter.
I think if I were dumping fuel, I would have stopped filling that tank.
jim
Old 05-20-2016, 08:14 AM
barberman91
Trailering
I'm not sure if the previous owner did any work to it. I'm going to get under there this weekend and see if I can see what's going on.
Old 05-20-2016, 12:48 PM
95E150-'rustbucket''s Avatar
95E150-'rustbucket'
95E150-'rustbucket' is offline
Fuel spillage
I'm guessing that your fuel filler hose is cracked, allowing gas to pour out once the tank is full. Had the same problem a few years ago....replaced the hose with NAPA part NBH 1030, $17.49/foot per website a few minutes ago. I got 1 ft., slightly longer than necessary. I replaced the hose without dropping the tank, and I've got fat fingers...goes with the rest of my body.
Old 05-20-2016, 01:03 PM
barberman91
Trailering
Lol, I'm hoping it's something simply like that and don't worry my fat fingers also match the rest of my body.
RKDxpress
08-05-2012 08:41 AM
berry1234
06-01-2009 10:42 PM
Veetener
06-01-2005 11:48 PM
maticuno
General Automotive Discussion
09-12-2004 07:16 AM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
17
01-03-2004 07:06 AM
Quick Reply: Please help
