My truck has a noticeable amount of intake noise and I've been wondering if this amount of noise is really normal or not. I realize that with the turbo, a certain amount of noise might be normal.
In the video at the following link, the intake noise is clearly audible at idle and as I rev up the engine. Any thoughts?
Yep that's absolutely normal .. they're all clanky out the top .. i installed 7.3 rockers/fresh pushrods and it made a tiny bit quieter .. also what i find helps em' less clinky is powerservice additive and atf in the fuel ..
Okay, that makes sense. It's always sounded that way, but I had nothing else to compare it to.
