Can It Be?
Old Nov 1, 2008 | 10:32 PM
scatgo's Avatar
scatgo
Can It Be?
Can it be a intake leak that is making the hissing noise that i am getting? I replaced the exhaust donuts but I am still getting the noise. It starts to make the noise at 1000 RPM or just above that.
Old Nov 2, 2008 | 01:35 PM
Cuda_jim's Avatar
Cuda_jim
Wag: Ebpv ??
Old Nov 2, 2008 | 04:31 PM
scatgo's Avatar
scatgo
Originally Posted by Cuda_jim
Wag: Ebpv ??
Removed..........
Old Nov 2, 2008 | 04:51 PM
the_old_ranger's Avatar
the_old_ranger
I can't hear it, I don't know
Old Nov 2, 2008 | 05:05 PM
plowhand's Avatar
plowhand
Playing in the Dirt
To check the intake boots (post turbo) mix up some soapy water (heavy on the soap) and spray on the boots and around the clamps. I have found a few intake leaks this way. Oh yea, I forgot to mention that you will probably need to have it running about 1200 rpm or more to have enough boost to show a leak, so be careful when leaning over the engine spraying with the engine running that fast.
Old Nov 2, 2008 | 06:57 PM
scatgo's Avatar
scatgo
Thanks, any one know of a way to test for exhaust leaks? Dont see any soot around any connections. except a very Little around one of the manifolds. Just wiped the fire wall clean it was covered with soot but may have been old stuff. Some of it was way down low on the foil right behind the manifold.
Old Nov 2, 2008 | 07:14 PM
BlueMule's Avatar
BlueMule
Have you checked the studs that hold the manifolds to the head. They've been known to break off, and will either "hiss" or "tick"
Old Nov 2, 2008 | 07:24 PM
scatgo's Avatar
scatgo
They are all there.
Old Nov 2, 2008 | 07:29 PM
BlueMule's Avatar
BlueMule
Originally Posted by scatgo
They are all there.
I wish mine were, I've had one broken for a while and I don't feel like fixin it.
Old Nov 2, 2008 | 07:44 PM
scatgo's Avatar
scatgo
Yea, looks like it could turn into a nightmare. Bolts breaking, tight spots to work in. I guess I am just hoping its a intake leak.
