1978 - 1996 Big Bronco
Rear Window problem, Window down/motor toast
Old May 17, 2016 | 08:57 PM
ddwood55's Avatar
ddwood55
I searched and didn't really find an answer.
I need to know how to get the window up and the motor is fried. I managed to get the plug to the motor unplugged and pulled out where I could put a direct 12 volts to it, all it would do is spark and start burning the wires.
As y'all know you can't get to the motor with the window down, anyone have any idea how to get it up.
I read a post on Big Bronco.com and it said ford says you have to break the glass, I'm not willing to do that yet.
Thanks in advance,
Delos
Old May 17, 2016 | 09:42 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
You can unbolt the window from the track then pull it up
Old May 17, 2016 | 09:48 PM
ddwood55's Avatar
ddwood55
Are you talking about unbolting the side tracks the window runs in?
Oh and it's an 89 model
Old May 17, 2016 | 09:52 PM
ManfredVonRichtofen
No the window bolts to a pair of tracks that is on the window regulator which moves it up and down. Unbolt the bolts from that track and window and you can pull the window up.
Old May 17, 2016 | 10:04 PM
ddwood55's Avatar
ddwood55
I thought about that but it really looks like they are riveted to that bottom window frame.
Old May 17, 2016 | 10:23 PM
ManfredVonRichtofen
Might have to take them out and replace with a bolt and lock nut.
Thats the only way i know especially if it is too far down
Old May 17, 2016 | 10:44 PM
ddwood55's Avatar
ddwood55
Yeah it's all the way down, not much room. I'll look at it some more tomorrow evening.
Thanks for your help
Old May 17, 2016 | 10:46 PM
ManfredVonRichtofen
Yes, may have to use a dremel and grind the rivet off then softly push or punch the other side out
Old May 24, 2016 | 04:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper picture:
23240 is the window roller, fits into the 44000 regulator, then into the 422A20 window channel.
Aratic
Nov 22, 2017 12:58 PM
Javier89F150
Jul 23, 2015 01:43 PM
adrock
Mar 16, 2005 08:50 PM
markmacd
1997 - 2003 F150
Dec 31, 2003 09:32 PM
Cameo
May 27, 2003 11:42 PM
