Frustrating transmission issues
Old May 16, 2016 | 11:42 AM
HKusp's Avatar
HKusp
I have posted about my transmission several times. I typed up a long new post for about 90 minutes describing in detail a bunch of symptoms and what happened this weekend pulling about 8k pounds worth of camper to the races Friday and accidentally deleted it, so it is even MORE frustrating at this point. I don't think I have the patience to do it again.
I basically had a situation where the transmission had a confused shift, temp got hot, after the funny shift, it wouldn't lock the torque converter and shift into 4th gear. I pulled over, attempted to pull codes with Torque pro, but it wouldn't do it. Babied it to the races and then again back home last night. Pulled codes with AE this morning and got:
P0733 - Gear3 Incorrect Ratio
P0750 - Shift Solenoid A
Now what?
Old May 16, 2016 | 12:16 PM
Otto396's Avatar
Otto396
Maybe a bad wire? Or the shift solenoid is wearing out? I wish I knew more about these damn transmissions.
Old May 16, 2016 | 03:00 PM
HKusp's Avatar
HKusp
Me too...hoping to have Mark look at this,
Old May 16, 2016 | 03:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That means solenoid A got stuck. New fluid may take care of it, or you may have to replace the solenoid body.
Old May 16, 2016 | 03:20 PM
HKusp's Avatar
HKusp
Thank you Mark.
Old May 16, 2016 | 03:27 PM
HKusp's Avatar
HKusp
Would any of that cause the torque converter to not hold under partial throttle or the slip reading on Torque Pro to read 1000 RPM higher than the engine RPM at idle?
Old May 16, 2016 | 08:57 PM
Mark Kovalsky
No, it would not. There is no way any speed sensor can be at a higher RPM than the engine when it's at idle and the truck isn't moving.
Old May 16, 2016 | 09:09 PM
snknby123's Avatar
snknby123
HKusp,
I have a spare "used" solenoid if you end up thinking that's your prob. LMK
Johnny Goode
Jun 28, 2018 08:47 PM
Chris Petzke
Apr 8, 2018 05:46 PM
dla2015
Aug 19, 2017 02:54 PM
CanadianSmokie
Nov 23, 2009 04:56 PM
bubbasz1
Mar 21, 2009 08:45 PM
