Sponsored by: Real Truck
2-3 shift solenoid fault
Old Mar 21, 2009 | 11:42 AM
bubbasz1's Avatar
bubbasz1
I've been toying for the last week or so with my son's 4r100, the trans was rebuilt (broken mechanical diode). We have had a couple of other issues but I am stuck on a once in a while 2-3 shift fault. Drove it all day yesterday no problems, out for a ride today had a couple of high RPM shift from 2-3 (3,000) and then a fault. Cleared and faulted three times in a row and then back to normal. The wife says buy the shift solenoid pack and be done with it, I like to have some kind of positive reashurance that I'm buying the right thing. I have cleaned the grounds around the truck, added a direct ground wire to the grounds coming out of the pcm bundle. Any other thoughts or checks before I pull the purchase of a new solenoid pack, and should I buy Ford or one of the so called (high performance ) packs you see on the internet.
Old Mar 21, 2009 | 08:06 PM
bubbasz1's Avatar
bubbasz1
Somebody has to have a comment at the very least.
Old Mar 21, 2009 | 08:12 PM
senix's Avatar
senix
at this point I think the wife is right. buy the part.
Old Mar 21, 2009 | 08:29 PM
grinekb's Avatar
grinekb
this is gonna sound crazy, but i have had a lot of transmission problems past month or two. finally broke down and took it to a transmission shop. the temp sensor caused all my shifting issues and the gear skipping.
Old Mar 21, 2009 | 08:45 PM
bubbasz1's Avatar
bubbasz1
Nothing is crazy with these electronic transmissions sometimes you have to think outside the box.
That sounds like the way to go, I just figured somebody would come up with something to try, I can't order one until Monday anyways.
welbo97
Nov 26, 2025 11:11 AM
chaso2
Sep 5, 2012 01:00 AM
terrysumner
Jan 19, 2011 09:21 AM
goosefreak
1983 - 2012 Ranger & B-Series
23
Feb 11, 2007 04:21 PM
