2002 E150 Transmission
Old May 26, 2016 | 07:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your idle pressures are about 30 PSI. Stall pressures were low, but barely acceptable in all except 1, where they were clearly below spec, and it looked like it dropped before I heard the engine speed change. I think there is a leak in the forward clutch circuit. Usually this is from a seal failure inside the clutch.
That attachment also has EPC pressures and shows the EPC tap. That would be another good test to do. If the EPC is wrong all the pressure will be wrong, and that can be fixed with a new solenoid.
Old May 26, 2016 | 06:28 PM
occupa's Avatar
occupa
Thanks I will get to it this weekend
Is the EPC tap also 1/8 NPT?
Old May 26, 2016 | 07:45 PM
Mark Kovalsky
Yes it is. All the pressure taps are the same thread.
Old May 28, 2016 | 10:15 AM
occupa's Avatar
occupa
Mark;
I got a chance to review again
And you were right I did not hold the throttle open long enough
Line pressure at idle 30 PSI Park and Neutral which is on the low side of the specification
WOT
Reverse 250 PSI within specification
Drive, 2, and 1 200 PSI on the lower side of 190 to 230 PSI
The pressure at one was not stable but fluttered between say 180 and 200 PSI
Delay on engagement happens when moving from N to D.
Does not happen when going from N to 2
Does not happen when you release the brake from a stop and the depress the gas.
I can tell when it will not engage as the gage flutters and is not stable. So if I move from Neutral to drive, gauge goes up to 75, but rises and falls below the nominal pressure rapidly. Once it settles the transmission engages. Settling generally can be achieve by giving it gas.
Sometimes is it is stable, but will not engage and a tap on the throttle will cause the gauge to jump and then engage.
Need to let it cool down for the EPC test I will update later today
Old May 28, 2016 | 01:57 PM
occupa's Avatar
occupa
Results from EPC tap
Idle
Park and Netural no deflection on the needle.
Reverse
10PSI
Drive, Second, and First
17 PSI
WOT
Reverse
90 PSI
Drive and Second
100 PSI
First
60 PSI
Looks like Idle and WOT first are out of specification
The document refers to Pinpoint Test E to diagnose EPC problems.
Would that be the next step?
Old May 28, 2016 | 09:14 PM
Mark Kovalsky
Yes it would.
Old May 29, 2016 | 06:50 PM
occupa's Avatar
occupa
Mark;
I am unable to find Pinpoint Test E.
Would you have the document?
or
Could you described the test?
Old May 29, 2016 | 07:01 PM
occupa's Avatar
occupa
Mark;
Excuse the ring I found it.
and attached.
I will look at it tomorrow.
Old Jun 5, 2016 | 07:47 AM
occupa's Avatar
occupa
Pinpoint test E focused on the output shaft speed sensor mainly using the scan tool.
Change the sensor with no change in the problem.
Old Feb 9, 2017 | 06:15 PM
occupa's Avatar
occupa
The problem I described is referred to "delayed engagement"
I found a shop in my area that could identify and repair with our "re-build"
They installed a sleeve an a pin to fix my problem
Drove from Ohio to Connecticut and back.
Thanks for your help and input.
Hope this helps others
Old Feb 10, 2017 | 05:48 AM
Im50fast's Avatar
Im50fast
My 07 V10 van (5speed automatic) recently began to delay for 2-4seconds when I shift to D or R. Seems the same as what you described.
Right?
What at exactly was the fix? I didn't understand
Old Feb 10, 2017 | 05:49 AM
Im50fast's Avatar
Im50fast
Woops posted in wrong thread
Old Feb 10, 2017 | 10:52 AM
  #28
jeffreyclay's Avatar
jeffreyclay
After following this thread I can safely say the days of throwing in a "master overhaul kit" to resolve all problems are gone. I'm referring to C-4's, FMX's and C-6's in the Fords. Until I reviewed the troubleshooting pdf's that Mark shared I had no idea of how much control has been turned over to electronics. Way more than a TV rod and a vacuum modulator. I'm sure there are certifications for technicians to stay abreast of technology. Can privately owned shops access training and support equal to dealership level? Just curious.
WLDHRSE
Dec 17, 2017 10:38 AM
Kristycush
Sep 30, 2016 02:08 AM
JR58
6.4L Power Stroke Diesel
May 16, 2016 09:17 AM
mx21
15
Oct 11, 2014 06:47 PM
Unrealo4
Mar 31, 2013 10:11 PM
