6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Slow shift into first
Old Apr 28, 2016 | 11:18 PM
JR58's Avatar
JR58
For the last 6 or 7 mos. my 08 F-350 has been slow to shift into 1st when shifting from park or reverse, whether it is a cold start or warmed up by driving. Trans shop says go ahead and rebuild it to the tune of 3-4k.
Might as well, gotta' be in there anyway, right?
All the other shifts are normal. That 5-8 second delay is getting bothersome.
Any suggestions?
Old Apr 29, 2016 | 07:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's probably a sticky solenoid. A rebuild will fix that, but there are less expensive ways. You could just replace SSA. Or you could change the fluid, sometimes new fluid will unstick a solenoid.
It is also possible that you have a bad seal in the forward clutch. A pressure gauge in the test port should show low pressure during the delayed engagement if this is the problem. If it is the problem, a rebuild is in order.
Old Apr 29, 2016 | 11:09 AM
JR58's Avatar
JR58
Mark,
Thanks for the reply, I'm praying for a solenoid and not a re-build. That being said l'll go ahead and change the fluid, cheapest fix first, right?
Should a re-build run in the 3-4k range?
Old Apr 29, 2016 | 01:10 PM
Mark Kovalsky
They can be that expensive.
Old Apr 29, 2016 | 02:33 PM
JR58's Avatar
JR58
I was afraid you were gonna say that.
Old Apr 29, 2016 | 08:03 PM
CrazySob's Avatar
CrazySob
If a rebuild is in order you are almost always better off dropping a Ford reman in, you end up with a warranty...
If you are tuned and running any kind of race tune then that's a whole different story.
Old Apr 29, 2016 | 09:07 PM
JR58's Avatar
JR58
Deleted only, no hp tune. But I get the point.
Old Apr 29, 2016 | 09:55 PM
CrazySob's Avatar
CrazySob
You could try switching tunes or having the tunes edited by whoever wrote them (assuming you have custom tunes).
Old May 16, 2016 | 09:17 AM
JR58's Avatar
JR58
Not a custom tune. Gearbox Z DPF-R only. Is it possible that a "re-install" of this programmer would help? I've not heard of this being a fix...just curious if anyone else has experienced the same thing.
Thanks for all of your comments.
F350fireman
Feb 21, 2017 07:40 AM
occupa
27
Feb 10, 2017 10:52 AM
grainofsalt
Aug 24, 2014 09:47 AM
Fasterhorses
1997 - 2003 F150
Oct 30, 2006 10:07 PM
lanecabs
Mar 22, 2004 05:59 PM
