O2 Sensor
Old May 6, 2016 | 11:07 PM
rlay302's Avatar
rlay302
O2 Sensor
O.K. I bought my son a 2002 Ford Edge (V-6 4.0)and was looking everything over and I see the 02 sensor on the passenger side exhaust and it's not hooked up to anything. I've even taken the inside fender off to get a better look. And I can't find where it plugs in.
Old May 7, 2016 | 08:07 AM
pawpaw's Avatar
pawpaw
Are you saying that the passenger side up stream O2 sensor pigtail is dangling loose & can't find the wiring harness end connector to plug it into???
Old May 8, 2016 | 09:19 PM
rlay302's Avatar
rlay302
Yes Sir, that's exactly it. I can't find where to plug it into the wiring harness? It's screwed into the passenger side exhaust and just hanging there. I've even taken the inner fender off to help myself locate it.
Old May 8, 2016 | 11:40 PM
pawpaw's Avatar
pawpaw
Ok that's good feedback, but my 99 has a different engine, so maybe a member reading this that has the 2002 OHC 4.0L will chime in & tell you where to look along the wiring harness for the passenger side upstream O2 sensor connector break out on at least a 2001 or newer 4.0L.
Old May 10, 2016 | 10:47 AM
reddog99's Avatar
reddog99
On my 2004, the harness that goes to the O2 sensor on passenger side pipe (just aft of the passenger side converter) loops down from over the top-rear of transmission. In my truck, that tranny is an automatic.
Edward W Rudhman
Jun 10, 2018 09:46 AM
GregonVI
Sep 17, 2013 10:26 AM
JOE SKI
1997 - 2003 F150
Nov 4, 2008 12:21 PM
n_ueland015
Electrical Systems/Wiring
Aug 11, 2007 02:08 AM
rsf
Jun 5, 2000 09:38 PM
