88 F150 o2 sensor plug
Old Jun 10, 2018 | 02:22 AM
Edward W Rudhman's Avatar
Edward W Rudhman
I have a 1988 F-150 with the 4.9L . I found the plug to the o2 sensor just hanging with what's left of the wires one the harness side. I'm having a hard time figuring out what the o2 plug was wired into. Anyone know? Every once in a while the truck seems to hesitate while speeding up, and then it "kicks" in and goes. I am wondering if the o2 sensor not being connected to the system would cause this?
Old Jun 10, 2018 | 08:13 AM
Nate8688's Avatar
Nate8688
Good morning,
I have the same truck and almost the same problem, except in my case the wiring connector is still in place, it's just that the o2 wires themselves are partially severed. I will go out and take a picture of the harness/connector that the o2 clips into as soon as I'm done with my coffee. I'll post it here shortly.
I aim to replace my o2 sensor if I can remove it myself, although 30 years of heat cycles seems to have welded it in place. If you opt to remove/replace yours please pass along any tips on how to get the bugger OUT.
Old Jun 10, 2018 | 09:20 AM
Nate8688's Avatar
Nate8688
I'm not able to upload the picture from my computer to the site for some reason, but I'll describe it as best I can.
If you're looking at the o2 sensor, to the front (of the truck) and above it is a black ribbed wire harness. About a foot to the front of the 02 sensor, coming from the black harness, is a wire with a plastic connector that the o2 clicks into. That's how it looks on mine, if I can get the picture I took to upload later I will.
Old Jun 10, 2018 | 09:46 AM
Ham Gravy's Avatar
Ham Gravy
Without the o2 sensor in the circuit, the computer might get 'confused' and not give a proper feed of fuel. I had an o2 sensor on my '95 4.9L 5spd that physically cracked, after hitting a pothole, and I had hesitation issues, that I could work around by upshifting or downshifting.
JoePeeper
Jul 7, 2013 07:40 AM
wrenchman2
Exhaust Systems
17
Nov 18, 2011 05:03 PM
charlie00tj
Bronco II
Jul 16, 2010 05:22 PM
n_ueland015
Electrical Systems/Wiring
Aug 11, 2007 02:08 AM
ford5.8
Exhaust Systems
18
Oct 9, 2003 02:35 PM
