Sponsored by: Real Truck
Starter Problems
Old May 6, 2016 | 09:44 AM
lj8215's Avatar
lj8215
Starter Problems
2002 Ford 7.3L 2WD 200K miles
My starter was making a grinding noise and the bolts had backed out. Wound up replacing the starter all together. Seemed to work for a little while and then went back to making the grinding noise again. I took the starter back and got a warranty replacement and took it to the shop last week to have it installed with lock-tite. It worked perfectly for a few days and then went back to grinding again yesterday afternoon. Any idea why it is still doing it? I bought a new Duralast Gold 5154 starter from Autozone. Any help would be greatly appreciated!
Old May 6, 2016 | 12:35 PM
89LX306's Avatar
89LX306
I would bet that it is not the starter that is the problem, but the motor/trans adapter plate that the starter mounts too. On my 2002 the threads in the plate stripped over time after the bolts loosened several times. I ended up replacing the plate when I put a new transmission in.
Here is a good thread that shows the plate.
https://www.ford-trucks.com/forums/8...t-problem.html
cutlass
Sep 20, 2012 08:51 AM
granny_rocket
30
Jun 28, 2012 07:47 PM
ohiostater
Oct 16, 2010 09:09 PM
lref1
1997 - 2003 F150
Mar 7, 2007 09:28 PM
Broncobirdy
1978 - 1996 Big Bronco
Dec 19, 2003 07:52 PM
