Starter grinding
Old Sep 19, 2012 | 09:37 PM
cutlass's Avatar
cutlass
Starter grinding
I have just started up my Ford reman. engine for the first time and I have a new flex plate as well. I hadn't started it up ten times when it began to grind. *****. The starter is pretty new and it had done this on my previous engine as well.
When I took out the old flex plate along with the old engine, it was absolutely trashed. I had the starter sent back to where I got it and they did some testing on it and told me it was all within specs.
Has anyone else battled a grinding starter and where you ever able to resolve the issue?
Thanks,
Drake
Old Sep 19, 2012 | 11:49 PM
BigAlsPSD's Avatar
BigAlsPSD
Grinding when starter is being actuated, or after the motor is running?
Even though they are not suppose to need it, would shimming the starter resolve the issue?
Old Sep 20, 2012 | 12:43 AM
cutlass's Avatar
cutlass
It's grinding when the starter is being actuated. I thought that shimming it would pull the starter gear further away from the flex plate when engaged (and disengaged) or do I not properly understand how this thing works?
Drake
Old Sep 20, 2012 | 02:06 AM
BigAlsPSD's Avatar
BigAlsPSD
Shimming would help if it was "dragging" like after the motor was running, like you said, by moving it away from the flywheel/flexplate.
If it's doing it while it actuates, then it sounds like a possible voltage/connection issue or a bendix issue.
Old Sep 20, 2012 | 07:52 AM
dn29626's Avatar
dn29626
Might be the starter drive. I had my drive replaced because of grinding. Problem resolved.
Old Sep 20, 2012 | 08:38 AM
cutlass's Avatar
cutlass
What's the starter drive?
Old Sep 20, 2012 | 08:39 AM
cutlass's Avatar
cutlass
Why would a voltage/connection issue cause the grinding?
What is a bendix issue?
Old Sep 20, 2012 | 08:51 AM
lartross's Avatar
lartross
..........I put out the wrong info the first time [relying on my memory....]a Bendix starter has a helical cut shaft so that when the starter rotates, the pawl move out and engages the flex plate...when the motor starts and the flex plates goes faster than the starter, it runs the starter pawl back toward the starter. I guess an issue would be the thing stuck out...or something like that..
WaveyDavey1980
Apr 18, 2019 09:31 PM
mikeytheeye
Nov 3, 2016 01:20 PM
Tim J
15
Jan 5, 2015 09:15 PM
granny_rocket
30
Jun 28, 2012 07:47 PM
daveeich337
25
Mar 3, 2008 07:37 PM
