OEM in bed trailer plug install question
Old May 3, 2016 | 09:07 PM
elee3's Avatar
elee3
I'm looking to install this OEM in bed trailer connector but there are no instructions or templates. Does anyone have a photo of what the hole looks like? Of course it's not the standard 2" round hole.
Old May 3, 2016 | 09:28 PM
Dpica15's Avatar
Dpica15
I installed this in my truck and just drilled a round hole and then riveted the plug
Old May 3, 2016 | 10:13 PM
elee3's Avatar
elee3
So, did you remove the riser piece and just mount the plug? On my last truck, I just bought a pollack plug and mounted it in a round hole, but this time I got the OEM one and it has these tabs sticking out of the back.
Old May 4, 2016 | 12:22 AM
swarf_rat's Avatar
swarf_rat
I had the same problem with it. The OEM installation must cut an odd shaped hole. I ended up removing the plug from the plastic standoff and making my own.
Old May 4, 2016 | 06:33 AM
elee3's Avatar
elee3
Nice job Swarf rat!
Old May 4, 2016 | 08:08 AM
Ginther's Avatar
Ginther
Here's MY THREAD on how I installed my plug.
Old May 4, 2016 | 09:35 AM
elee3's Avatar
elee3
Thanks for the link Ginther. I'll probably end up mounting it without the standoff piece like you did.
You really got a deal on that junkyard find.
Old May 4, 2016 | 09:53 AM
Ginther's Avatar
Ginther
Glad I could help.
I try to save a few bucks on recycling good parts off wrecked vehicles when I can.
I removed the tailgate handle (stripper pole) and got a regular metal panel for the tailgate for something like $20 from the same truck. Just have to get it sprayed with bed liner like the rest of the bed now.
Old May 6, 2016 | 08:01 AM
porthole's Avatar
porthole
Why not just drill a round hole and cut the tabs off ?
Old May 6, 2016 | 08:51 AM
elee3's Avatar
elee3
I found a thread where a guy did that, and I considered it. In the end I decided to mount it the same place that I did on my 2012, which is lower and near the wheel well and doesn't require the standoff. This location works well for me. I feel like the wheel well helps protect it and the wire doesn't hang up on my cooler (near the tai gait) when turning.
Old May 6, 2016 | 05:58 PM
pjcinmi's Avatar
pjcinmi
A little late to the game.
But.. I cut the tabs off on the large mounting plate, and drilled a round hole. I also used S/S Nut & Bolt for mounting it. Further, I mounted it higher and closer to the tailgate, so that I don't have to climb into the bed to hook/unhook it. (The pull switch is for the Bed lights I added)
The funky cut out picture is the factory cut out I found on the web when I was doing mine.
P.S. You need to use the large plate if you are mounting it high, as the pig tail wires won't clear the inside bed.
Old May 6, 2016 | 08:26 PM
swarf_rat's Avatar
swarf_rat
Hey, you installed that thing upside down!
Old May 6, 2016 | 10:22 PM
pjcinmi's Avatar
pjcinmi
Na... I was standing on my head, when I took the picture.
Ginther
Oct 13, 2021 09:37 PM
D.Yaros
Electrical Systems/Wiring
May 25, 2015 02:56 PM
bakerbuilttracks
All Things Towing
Nov 11, 2013 05:10 AM
freesoul
Feb 11, 2012 06:58 PM
labman1014
Nov 19, 2010 05:55 PM
