Loud grinding coming from driver side
Old May 3, 2016 | 07:54 PM
Littlemonster250's Avatar
Littlemonster250
I have a 86 f250 4x4 7.5 xl
I've been hearing a noise coming from the drive side area you can feel it though the floor boards. It starts to make noise around 25-30 mile an hour.
I've read post but it all talks about turning it makes the noise go driving forward with no turns.
I've check out the ball joint checked out the front axle not sure if anyone has more ideals thanks for reading
Old May 4, 2016 | 09:48 AM
1986F150six's Avatar
1986F150six
Does the noise change when brakes are applied? Are the tires in good condition? Does the noise [going straight] change if making a turn?
Old May 4, 2016 | 02:33 PM
Littlemonster250
Sound
When I apply the brakes it slows the noise down. Turns while driving same noise as if in just driving straight the tires are about 40 percent
Old May 4, 2016 | 02:55 PM
1986F150six
Switch the two front wheels... left to right and right to left, and see if the noise switches to the passenger side.
Old May 4, 2016 | 07:10 PM
Littlemonster250
Still get that metal grinding noise
Old May 5, 2016 | 09:54 AM
1986F150six
Wheel bearings?
Old May 5, 2016 | 07:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wheel bearings?
Would be my guess.
Old May 6, 2016 | 04:11 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Unless both front rim/tire assemblies have been recently balanced, switching them really wouldn't be a good indicator as each of them may have individual issues respectfully. I would have to agree with the responses that it points to the wheel bearing(s). If you replace one side...replace the other side also. Keep the front end symmetrical.
Old May 6, 2016 | 06:14 PM
kr98664's Avatar
kr98664
How much material is left on the brake pads? Are the inner and outer pads worn about the same amount? If not, that would point to calipers sticking on their rails.
I've run down brake pads too far and caused a horrible racket. Severely worn pads generally make more noise when the brakes are applied, but who knows. Debris trapped under brake pads can also cause lots of noise. Do you happen to have aftermarket GM-style pads with the wear limit squealers? Wouldn't cost anything to inspect the pads, and they've got to come off anyway to access the wheel bearings.
I've had wheel bearings fail, but that was more of a low rumbling noise. Slop in the steering (especially on freeway ruts) was more apparent than the noise. That's what had me leaning more towards the brakes.
Old May 6, 2016 | 10:27 PM
WhatsAChevy?
When you apply the brake, the noise will slow down because the brake caliper is
"truing up" the rotor and bearing(s) to be in-line. Like a horse with blinders on. The caliper, with pad is "fixed", compressing the rotor, causing it to run "true", therefore causing the bearing to run the same. Without compression, the worn bearing is allowed to falter at will. Wow....I hope this makes sense.
Old May 7, 2016 | 06:46 AM
FuzzFace2's Avatar
FuzzFace2
To me it does: brakes applied act as aguide to make the rotor run true as you said.
No brakes applied the rotor & wheelbearing run willie nillie and make noise.
Dave ----
Roadtriptruck
Jun 14, 2016 12:34 PM
5-oh-my
Jan 8, 2010 04:08 PM
351fordpower
1997 - 2003 F150
Apr 4, 2006 03:23 PM
deaddux
1997 - 2003 F150
18
Jan 17, 2006 08:50 PM
expedition99
Aug 12, 2002 07:44 AM
