HELP 7.3 cuts off
Old May 25, 2016 | 12:22 PM
  #46
Rikster-7700's Avatar
Rikster-7700
Originally Posted by 02stroke
Pressure is at 2.51 when idling, drops to.60 when I step on the pedal
what pressure are talking about here? it can't be fuel pressure as there is no fuel pressure sensor built in to these trucks from the factory, and your FP should be up around 60 PSI idle
Old May 25, 2016 | 12:52 PM
  #47
02stroke's Avatar
02stroke
That's from his Snap On Solus Edge scan tool
Old May 25, 2016 | 12:55 PM
  #48
02stroke's Avatar
02stroke
Originally Posted by Nicmike
Check the FPR spring on the return line back to the fuel tank. Also, has your fuel bowl been rebuilt yet over the course of the truck's life?
I have a FRX on it, I rebuilt the fuel bowl 2 years ago, but with all the stuff that came out the tank it probably is clogged
Old May 25, 2016 | 01:26 PM
  #49
mb_01sc's Avatar
mb_01sc
I haven't personally experienced this, but have you tried unplugging the fuel bowl heater? Was the bowl heater replaced when you rebuilt it?
It was a suggestion sent my way under similar circumstances. I believe they normally short and blow a fuse, but maybe a draw issue?
Sorry if I missed you mentioning this one already.
Old May 25, 2016 | 01:35 PM
  #50
Rikster-7700
Ok, but what pressure is it referencing?
Old May 25, 2016 | 02:35 PM
  #51
HKusp's Avatar
HKusp
That is NOT a correct fuel pressure. As was stated earlier, you don't have a fuel pressure sensor on your truck unless you plumbed one yourself, (or the previous owner) and if that were the case, the PCM wouldn't be reading it, and therefore neither would the Snap On scanner. You would have an aftermarket gauge somewhere if it were added, no way that Snap On would be pulling that from the OBDII port.
Old May 25, 2016 | 03:49 PM
  #52
02stroke's Avatar
02stroke
OK Lots of updates. First of all, it is fixed! I called my cousin who is in the Navy and works on these trucks & other Diesel equipment. He told me to put the Mechanic on the phone. He told him to crack cylinder #8 and #1 and bleed them. It was air the system the whole time. The truck response is the best I have seen it. It BETTER be since I have all this new parts. I want to thank ALL of you who helped me diagnose this thing. You guys are the best, and I am thankful to have this wealth of knowledge at my fingertips. If only you guys could teleport over here when I need you, LOL. Thanks All!
Old May 25, 2016 | 04:35 PM
  #53
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Sweet! :-) :-)
Old May 25, 2016 | 04:47 PM
  #54
Pikachu's Avatar
Pikachu
How does one "bleed" an injector that doesn't have high pressure injection lines going to it?
Old May 25, 2016 | 04:49 PM
  #55
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I think he is talking about the lines going to the cylinder heads...just terminology I think.
Old May 25, 2016 | 05:17 PM
  #56
02stroke's Avatar
02stroke
Yes, the lines going to the heads. I'm learning!
sdbguitarman
16
Jun 30, 2019 05:05 PM
radmacks
Feb 23, 2016 12:19 PM
bulletpruf
Aug 12, 2012 01:31 PM
bjohndev6789
1983 - 2012 Ranger & B-Series
Aug 9, 2005 08:28 PM
ChargerFan
Oct 6, 2004 07:31 PM
