HELP 7.3 cuts off
Old May 21, 2016 | 10:26 AM
  #31
02stroke's Avatar
02stroke
I've replaced ipr, same issue happening. Met a guy who said he'd look at it (International guy) he said it could be idm. Does anyone know the issues with idm?
Old May 21, 2016 | 03:39 PM
  #32
02stroke's Avatar
02stroke
Ok just replaced IDM, same issues, except now I'm broke and still no truck
Old May 21, 2016 | 04:00 PM
  #33
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Apologies for not reading the whole thread;
Have a CEL? Way to read codes? New (not rebuilt) IPR I see, but ICP sensor?
Old May 21, 2016 | 04:55 PM
  #34
02stroke's Avatar
02stroke
I went to the stealership and paid $300 for a brand new IPR, I did not do the icp
Old May 22, 2016 | 11:32 AM
  #35
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Have you ever checked fuel pressure?
Old May 22, 2016 | 01:45 PM
  #36
02stroke's Avatar
02stroke
He (mechanic) said he checked the pressure and it was good. He said he let the truck warm up for 20 mins, with no problems, as soon as he put it in drive it stalled. Now he says it could be the pedal sensor, I'll have a whole new truck by the time I finish throwing parts at it
Old May 22, 2016 | 04:27 PM
  #37
Whitey Ford
Is he monitoring fuel pressure when it stalls? Check the fuel bowl to see if it is full after it stalls.
Old May 23, 2016 | 02:40 PM
  #38
02stroke's Avatar
02stroke
He said that when it stalls the fuel in the bowl drops 2-3 inches
Old May 23, 2016 | 03:07 PM
  #39
Rikster-7700's Avatar
Rikster-7700
Sounds like you need a new mechanic?! Throwing parts at these vehicles to try and fix an issue gets extremely expensive, and quick!
Old May 23, 2016 | 03:14 PM
  #40
Whitey Ford
So it is either a restriction in the tank or the pump. Under load it is unable to supply the proper amount of fuel. You said the tank was full so the foot should not be the issue, but those screens on the foot could be clogged, but didn't you get some sort of fuel pump wiring code earlier?
Old May 23, 2016 | 05:31 PM
  #41
02stroke's Avatar
02stroke
Definitely, picking it up tomorrow
Old May 23, 2016 | 05:32 PM
  #42
02stroke's Avatar
02stroke
gonna do the Hutch Mod and get a new Pump
Old May 25, 2016 | 11:50 AM
  #43
02stroke's Avatar
02stroke
Ok new pump, I did the hutch mod, now seems better but still stalking when u put it in drive. Hooked to a scanner, and pressure drops WOT. What could this be?
Old May 25, 2016 | 12:09 PM
  #44
02stroke's Avatar
02stroke
Pressure is at 2.51 when idling, drops to.60 when I step on the pedal
Old May 25, 2016 | 12:19 PM
  #45
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Check the FPR spring on the return line back to the fuel tank. Also, has your fuel bowl been rebuilt yet over the course of the truck's life?
