x pipe or an H pipe
Old May 2, 2016 | 09:26 PM
Trent Racer's Avatar
Trent Racer
Question x pipe or an H pipe
i want to know the pros and cons of the x pipe and h pipe and if any of you guys have seen power gains or more low end torque
current exhaust: Longtube headers (flowtech) true duals no crossover pipe gutted cats 12 inch glasspacks dumped at the rear axle
and this is a 1989 f250 with a 351w
Old May 2, 2016 | 10:55 PM
whisler's Avatar
whisler
I have the same truck with the same engine and shorty headers. I'm running duals with no cats and an H pipe. Seems to pull well for me.
Old May 3, 2016 | 09:44 AM
LARIAT 85's Avatar
LARIAT 85
It was explained to me that the H-pipe helps with low-end torque and produces a deeper, classic muscle car sound. The X-pipe helps more on top end horsepower and produces a raspier, modern exotic car sound.
After running a true dual exhaust system (a separate exhaust pipe running from each header) since about 2009, a friend in the exhaust business convinced me to install a crossover pipe, or "H-pipe" between the two exhaust pipes. So I went ahead and did it, not expecting much difference.
To my surprise, the H-pipe made a VERY noticeable difference in my truck. Driving away, I felt the difference immediately. Although throttle response was always excellent with this truck, the H-pipe greatly improved low end power; I can actually feel the difference in the throttle. The engine seems to "breathe" better, as in I can accelerate MUCH easier and faster with less throttle pressure than before. The improvement feels like I fixed a sticking brake, or like I shed 500 pounds off the truck!
An added bonus came after I got home and got out to inspect the H-pipe location with the truck at idle: the exhaust note is now much deeper, much STRONGER. It now sounds like...a 5.0 Mustang!
Old May 3, 2016 | 09:55 AM
'89F2urd's Avatar
'89F2urd
Neither. Long tubes into a y is what maximizes torque production, and fitting x or h pipe somewhere on your truck is nearly impossible to do in a clean fashion.
Old May 3, 2016 | 12:33 PM
LARIAT 85's Avatar
LARIAT 85
I don't know about the Y-pipe "maximizing torque production" but the H-pipe was welded in between the transmission and the [Flowmaster] mufflers, on the passenger's side right past the door on my truck. I am running dual exhaust with a separate muffler on each pipe.
Old May 3, 2016 | 02:07 PM
'89F2urd's Avatar
'89F2urd
Y pipe = low end - mid range hp
X/h = mid-top end hp
Duals = worthless top end
Y pipe is best option for maximizing scavenging at low - mid engine speeds. It also takes a lot of rpm to exceed the capabilities of a good y.
Old May 3, 2016 | 02:44 PM
Motorhead351's Avatar
Motorhead351
Stock engine or mild, Id do an x or h for sound characteristics, not power gains.
Y pipe is what I run, into a single pipe, weight savings over duals and can sound ever but as good.
Old May 3, 2016 | 07:21 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv got duals with an H pipe in my '68 t-bird with 429.......sounds sexy.
77custom408
Exhaust Systems
Nov 15, 2012 04:45 PM
roddles78
Feb 2, 2010 06:11 PM
kkkd
26
Jun 3, 2009 03:26 PM
MemOrex
Exhaust Systems
Mar 29, 2006 04:48 PM
clean79150
Exhaust Systems
33
Jul 27, 2003 02:42 PM
