1990 transmission
Old May 3, 2016 | 05:03 AM
Donald Blankynship's Avatar
Donald Blankynship
1990 transmission
So I have a 1990 F150 with a completely shot E4OD in it. I bought an AOD by mistake and I don't want to be out of the money so I want to use it. What do I need to do to make that work?
Old May 3, 2016 | 06:55 AM
arse_sidewards's Avatar
arse_sidewards
You'll need a flex-plate, drive shaft(s), a shiftier cable, maybe a different transmission mount and you might need to move the transmission cross-member forward.
Old May 3, 2016 | 07:05 AM
rla2005's Avatar
rla2005
And a different computer if you want to keep the Check Engine Light off.
Old May 3, 2016 | 07:09 AM
arse_sidewards
IIRC there's ways to make it work. It's been awhile since I've ead up on the manual swap threads. The truck will run just fine without the E4OD, you may need to jumper two pins somewhere to get the light to go out.
Old May 3, 2016 | 08:35 AM
Lead Head's Avatar
Lead Head
You will also need the AOD throttle-valve cable and the associated hardware to connect it to the throttle body.
Old May 3, 2016 | 09:15 AM
timbersteel's Avatar
timbersteel
The AOD TV cable is unobtainium...
May find it for $100 on eBay or $50 @ the junkyard.
It's no longer manufactured by Ford and never been duplicated by aftermarket.
Lokar makes type of TV cable, but you have to make the cut and adjustment.
Old May 3, 2016 | 07:22 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Good thing I picked one of the cables and the bracket up at the junkyard a couple months ago. Never did make it back to get the AOD.
Seems like a lot of trouble to go through. There isn't a way to unload the wrong trans and procure the right one?
Old May 3, 2016 | 07:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
way too much trouble to downgrade.it might be worth the trouble if you had an aod and wanted to go e4 but not the other way around.
carsronnie86
Apr 22, 2016 09:26 PM
KaoticCreations
Jan 24, 2012 04:42 PM
bowmn01
Mar 11, 2009 06:22 PM
currituckF150
Jul 22, 2007 10:28 AM
javi2001
Aug 20, 2003 06:01 PM
