steering shaft removal question
Old May 2, 2016 | 03:11 PM
ktm4012's Avatar
ktm4012
I am removing the steering shaft in my 79 F250 4x4. I have the bolt out that attaches the u joint to the spline groove. Do I need to remove steering column to get U joint off spline? I did this before 20 years ago but I can't remember.
Old May 2, 2016 | 03:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4 speed or A/T?
Be aware there is no replaceable u-joint on 1976/79 4WD's, as it's made as part of the one piece lower steering shaft and coupler assy.
Old May 2, 2016 | 03:40 PM
ktm4012's Avatar
ktm4012
4 speed trans
Old May 2, 2016 | 04:36 PM
NumberDummy
4 speed trans
3B676 in pic is the one piece lower steering shaft and coupler, Ford did not sell any individual parts for it. It's obsolete, none are available NOS and it was very expensive when available.
Same 1978/79 F250 4WD & 1979 F350 4WD (D8TZ-3B676-B). The only thing you can do is replace it with an aftermarket Borgeson shaft.
3A525 is the 'rag joint' .. was not furnished with the coupling, was available by itself.
Old May 2, 2016 | 04:42 PM
mark a.'s Avatar
mark a.
I think it will go just sliding the column back and taking the 4 bolts that hold the weather seal to the firewall.
Old May 2, 2016 | 06:57 PM
J ballan's Avatar
J ballan
Usually the slip joint part of the shaft will get seized up making it hard to come apart. Get yourself a new borguson shaft to replace it with. They are well built units in my experience.
Dr mac
15
May 4, 2021 02:17 PM
rob8210
Oct 3, 2016 06:58 PM
03trueblue
Jun 15, 2012 10:44 AM
kilog55
May 1, 2008 05:49 PM
78bigunns
Dec 16, 2001 08:26 AM
