Scangauge SLP code
Old Apr 29, 2016 | 05:48 PM
Gatordog's Avatar
Gatordog
Scangauge SLP code
I can't find it but I say on this forum where someone was running torque pro and getting transmission slip percentage. I have a scangaugeII and in entered the codes for slip and I am getting nothing. Just wondering if the scangauge can read it.
I have a 2000 dually
Old Apr 30, 2016 | 09:41 AM
Tugly's Avatar
Tugly
The 2016 OBDII thread will have the information. I've been reading Torque Converter Slip on many OBDII apps for years.
Old Apr 30, 2016 | 01:47 PM
Gatordog's Avatar
Gatordog
Thanks Tugly, it seems to working now. I found one of your old postings "Torque Converter Slip
Short Name: Slip
PID: 2211b8
Units: RPM"
I noticed that the codes from Scangauge had 2211BA on the end of the transmit and receive codes. I changed the A to a 8 on both and I am getting a reading��
Don't know for sure if it is correct, what are typical readings for idle in gear, changing gears, cruising at 60 mph and hammer down.
Old Apr 30, 2016 | 02:31 PM
Tugly's Avatar
Tugly
I set my gauge MAX to 1000 because it makes a better image on the dial under normal circumstances - like idling in gear at a light. TCLU should be under 10 if the math is right (you can't get zero because of the data sampling rate). Neutral in the driveway shows something like 400-500 (I can't remember the exact number), in gear at the light should match your RPM, 300-400 RPM slip while driving without TCLU unless you're loading the engine up (like in Permagrin mode). The driving slip numbers are not precise - I'm going off memory, and I haven't been driving Stinky much lately. Idle in gear and TCLU numbers are very accurate in my memory - those are the two modes I have spent more time at.
One thing's for sure - you'll get to know the behavior of your torque converter under different driving conditions real soon.
Old Apr 30, 2016 | 07:41 PM
Gatordog's Avatar
Gatordog
Mine reads 0.04 in low gears, accelerate and goes up to 0.09 for a flash. I did see 0.11 coasting. So far just one short drive, will keep an eye on it. Scangauge does not log data like the other, but I like it.
Old May 1, 2016 | 11:13 AM
Tugly's Avatar
Tugly
You're off by many decimals, if using RPMs as a unit. I think where you are reading .04 you should read 400, and the .11 should read 1100. What happens if you put a X1000 in the formula?
Old May 1, 2016 | 01:02 PM
Gatordog's Avatar
Gatordog
There is no formula.
I say another post, and they were using a tablet, it showed 0.7 for slip. I am thinking it is % of slip
http://http://www.scangauge.com/support/x-gauge/ford-specific-xgauges/
explorerdriver
Oct 7, 2017 04:59 PM
tommyl
Apr 12, 2017 05:29 PM
F2502011
Mar 10, 2017 04:39 PM
HKusp
Nov 7, 2014 04:10 PM
tomridge
Dec 17, 2001 07:07 AM
