Automatic trans slip
Old Dec 14, 2001 | 10:12 PM
tomridge's Avatar
tomridge
Hi all,
I was wondering if anyone knew how much slip there is on a C6 transmission. Obviously a manual transmission has zero slip once the clutch is fully engaged. An automatic has slip through the torque converter, but what sort of slip would be considered normal? I guess what I am asking is with non locking converters what is the difference in engine rpm and transmission rpm on a properly operating automatic transmission.
Thanx for any info
Tom
Old Dec 15, 2001 | 11:58 PM
Ratsmoker's Avatar
Ratsmoker
TC slip is going to vary a little depending on the amount of torque your engine puts out. Above 2000 rpm with a stock converter you shouldn't slip much more than 300 rpm under full throttle. If you have a smallblock it may even be less.
Old Dec 16, 2001 | 09:20 AM
tomridge's Avatar
tomridge
300 RPM, that is a little better than I thought. Where did you get that number? I am not doubting it, just looking for a good source of information, Thanks for the reply.
Tom
Old Dec 17, 2001 | 07:07 AM
ludis's Avatar
ludis
hermannm2
2009 - 2014 F150
Jul 16, 2016 12:51 AM
jgraves
Apr 2, 2016 09:39 PM
TheOtherBubba
Feb 4, 2016 05:43 PM
68rs327
Nov 13, 2013 10:59 PM
satcomjimmy
25
May 10, 2006 02:15 PM
